Rear quarter window
Old Feb 10, 2020 | 12:29 PM
44lawrence's Avatar
Default Rear quarter window
I have to get to the rear quarter panel window motor on my 91 conv. Before I start I figured ask someone on how to take that interior panel off after removing the 3 screw.
Old Feb 10, 2020 | 01:54 PM
Vee's Avatar
Vee
Would help to know what car you have.
Perhaps adding a signature so that you don't have to remember next time?
Old Feb 10, 2020 | 02:58 PM
JayJagJay's Avatar
Not all the screws are so easy to see and I can't remember the exact number. After you remove them all, there are a few little tabs that run along the back shelf/cabinet where the cover 'catches' and there really shouldn't be much else. On my 1990, the waste seal ish thingy on the inside runs up against the 1/4 window pretty tightly and it takes a little pulling pushing,,, and you need to keep any eye on and mess around with the belt situation some. Should be toooo tough.
Old Feb 10, 2020 | 03:29 PM
ptjs1's Avatar
I'm not sure about the pre-facelift 2-seaters but on the late 2+2 cars, there are a couple of things that you need to consider:
- It's technically possible to remove the casing with the chrome sill plate in situ, but it's easier and less likelihood of damage of you remove the chrome door sill cover first.
- There are a number of hidden press clips in the B-post. It's very important to carefully locate them and prise them off from behind using a trim removal tool.
Good luck
Paul
Old Feb 10, 2020 | 04:12 PM
malc4d's Avatar
One screw behind the glass, you will need to lower the window. I left that screw out.. and 3 hidden press fit in the leather on the B post on the face lift. Is it a Pre face lift '91 ?
Old Feb 10, 2020 | 06:48 PM
44lawrence's Avatar
I did write the year, 91 conv ! Lawrence is my name
Old Feb 10, 2020 | 06:58 PM
44lawrence's Avatar
It is a 1991 convertible pre facelift. Non 2+2.(no back seat).
usaf
Dec 10, 2016 12:06 PM
davideoandthebeast
Oct 14, 2014 02:55 PM
al50bmgshooter
Aug 16, 2012 08:52 AM
SeismicGuy
Nov 19, 2011 05:31 PM
