rear sway bars
I am with Ronbros on this one. providing there is some negative camber on the rear wheels, and that the ride height is correct, I believe the XJS handles and corners better with no rear ARB.
The XJS understeers, Having the rear end flop over can help the car rotate in experience hands. On the street, under-steer is generally considered safer.
The better setup is to keep or install the somewhat thin stock rear bar and upgrade to a stiffer 1 inch front bar. This will make the back end soft relative to the front and offer up a more controlled rotation effect. I have driven a friends 1990 XJS with this setup and it's a great drive. He managed a 1:16 on a Limerock track day which is a good time for a novice in any car. The brakes over heated after 2 laps and Limerock isn't even a brake intensive track.
The Aston DB7 GT had a slightly larger rear sway bar and 1 inch front. That's the setup I use and the DB7 GT put down a good time for GT car at the Nurburgring Nordschleife. About 8 min. That's Amazing becasue that time was in line with other high end GT offerings of the day from Porsche and Ferrari. Many people dont know the DB7 was based on the XJS but the Front suspension geometry is more inline with the XK8 than a XJS.
i did install a 1" front bar ,when i took the rear off, way back 1994!!
truth is i dont drive really fast anymore , i'm turnin 85 this year, so gotta think about sellin the XJS HOT ROD!
i know ,but ever think what the hell would my wife do with it?
perish the thought!
ron
perish the thought!
ron
A basic understanding of chassis balance will tell you that if you stiffen the Front roll stiffness, you will tend towards understeer, while increasing the rear roll stiffness will tend towards oversteer.
Most aftermarket upgrades increase front and rear roll stiffness, but alter the front rear balance by shifting a little more to the rear.
The ability to adjust the front/rear roll stiffness balance, either by adjustable roll/sway bars or by replacing one or both of the bars, allows you to adjust how the car feels to the driver. Some drivers prefer a slightly ‘loose’ (oversteer) car, while others prefer a little understeer.
'Tis true.
On my XJS I had the 1" front bar and experimented with 3 different rear bars.
Jaguar used two different sizes in the rear, 13mm and 15mm....or something like that. I found and tried both. I also tried an Addco rear bar, which is something like 19mm.
The Addco bar was too much. The car became borderline treacherous.
Both of the smaller sizes were fine; the difference between them, subjectively, was not significant.
I’ve been offered an 18mm bar for the rear of my XJ6 that can be paired with either a 24mm or 27mm front bar. I’m thinking an 18mm Rear might work best with the 27mm front?
Choices, choices!
Choices, choices!
My XJS has a 1" (25mm) front bar and 7/8" (22mm) rear bar and it corners very flatly. The only time I have had oversteer is applying power in the wet on a corner, never a problem in the dry. The factory bar is 16mm rear I believe, paired with 22mm front.
I think you will have trouble fitting a 27mm front bar actually, as the 25mm leaves very little wall thickness of the bushing that goes into the brackets. I'm not sure you could fit bushing and a 27mm bar into the factory brackets.
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
