rear vented rotor...What calipers
Old Jun 27, 2014 | 06:55 PM
icsamerica's Avatar
Default rear vented rotor...What calipers
I have a XJS IRS in my XJ coupe and it has the rear vented outboard rotors. Does anyone know the application for the calipers so I can properly order a new set. The rear rotors appear to be about 12 inches wide and about 20mm thick.
Old Jun 27, 2014 | 10:34 PM
86jag's Avatar
Your calipers are the same as stock. Only difference is the spacers between the two halves and the brake fluid hose you will need to swap over.
Edit:
My apologizes: I thought you were referring to vented inboard brakes. For outboard vented disc just go to RockAuto.com and you can find rebuilt calipers for a 95/96 xjs.
Old Jun 28, 2014 | 06:25 AM
ptjs1's Avatar
icsamerica,
I'm sure you might be able to find a pattern part cheaper, but the right hand one is still available from Jaguar if you need it:
Brake Disc and Caliper-Rear - Parts For XJS from (V)179737 to (V)226645 | Jaguar Classic Parts UK
Good luck
Paul
H20boy
Dec 24, 2024 03:23 PM
danke
Mar 3, 2016 10:57 AM
Richard_gib
Sep 12, 2015 07:08 PM
timm525
Sep 8, 2015 07:57 PM
philwarner
Sep 5, 2015 10:05 AM
