Remove dash center a/c vent
Old May 12, 2020 | 12:19 PM
afterburner1's Avatar
Default Remove dash center a/c vent
Searched the forum but found nothing on removing center A/C vent (1993 XJS Coupe)
What I need to know is the WOOD FACIA "screwed in" or "snaped in" and the same for the PLASTIC VENT
If screw in (or other fastener) how do you get to them to remove?
Always thanks in advance for your help!
Old May 12, 2020 | 05:13 PM
Some Day, Some Day's Avatar
Snapped in. Get a long, flat knife or something, open the glove box, insert the knife in behind the wood, as close to the two prongs on that side as possible, and gently pry it off.
Prongs on the back.
The plastic vent just sits there, held in by the wood.
Central vents just sit in here, aligned with plastic ridges, but not screwed.
Note locations of prong holes on the left. Yours will be LHD, so mentally flip this image.
Old May 12, 2020 | 09:36 PM
Thank you. It is so easy when you can see what you are dealing with. I bought a center vent and plan to take its outer vents and move them to the center and from the center vent in the car I plan to take the outer vents and move them to the outer location on the vent I bought. That will give me four controllable vents in a row. Just a fun thing to do!
Went to your web site and was dually impressed. The pictures and cars are stunning. I particularly like the fabricated dash and would have liked to know what the switches were for. I made one for an XJ6 out of teak and It looked great finished in oil, but did not compare to your splendid efforts. I spent an R and R in Tokyo and Nagoya in 1952 from Korea. From your pictures things have changed! All I ever saw were pushcarts, very dilapidated cars and narrow streets. My car is black and beautiful and all original. This modification will be the first and can be remove back to original. Thanks for the removal info; it was appreciated
Old May 12, 2020 | 11:09 PM
No probs. And thanks for checking out Lady Mary's modest site. I haven't done anything new there for ages. Just too busy really. However, I'm confused by your mention of a "fabricated dash" - which dash are you referring to? It would have to be either one of the ones in a car that isn't mine, or perhaps some other website by mistake. Because mine's bog-standard normal. The only thing I've done is replace the 3-piece central vent with a newer 2-piece vent.
Seeing Tokyo and Nagoya in 1952 would have been impressive. I've only seen photos and old films of those days (and museum exhibits), but yes, things would have been very different indeed. Dramatically so. Way back before the economic recovery really took off, possibly even still while it was under Allied occupation depending on when exactly you were there.
Hoosier XK8
May 22, 2017 04:04 PM
al_roethlisberger
Nov 16, 2014 09:32 PM
Coz
May 30, 2013 09:14 PM
mlewisfwa
May 12, 2008 08:47 AM
michaelnv
May 11, 2008 02:46 PM
