Removing the complete airo system!! Possible???
Old Nov 18, 2010 | 03:51 PM
frederikv12beauty's Avatar
Default Removing the complete airo system!! Possible???
Dear all,
Is it possible to take the whole arco system of and not place it back??
I do not find the need to have it and it's in the way of general maintenance of the beautiful V12. Please give it a thought.
many thanks
Old Nov 19, 2010 | 04:50 PM
Don Neff's Avatar
Default Removing the A/C Compressor, etc.
Yes, you can remove the compressor, freon hoses, and condensor. I'd leave the the evaporator in place because it is a large amount of work to get at it.
Old Nov 19, 2010 | 10:44 PM
EcbJag's Avatar
Removing the air compressor means removing the belt that also powers the smog pump. I do not think you will ever pass smog without it. I may be wrong, but this is apparently the case with my '87. I had to put the A/C compressor back in before doing a smog test.
Old Nov 20, 2010 | 04:46 AM
@ECB, I am not so sure, OK on my UK spec XJ40 92, I do not have any of that EGR stuff or an air pump.
(Batt flat in camera, but when I can I'll post up a pick of my engine bay for you guys with EGR problems to drool over).
Old Nov 20, 2010 | 10:56 AM
EcbJag's Avatar
OH! I forgot that we were talking about a UK car here! I know that at least my N. America car has all this emissions stuff! I bought the car with the a/c compressor in the trunk ( which was the only thing wrong with it) and was told it must be replaced so the smog pump would work!
Old Nov 21, 2010 | 05:33 AM
Hi Guy's,
Thanks for all the comments. I do not think i have one of those SMOG Pumps on my Jag. As far as I understood i can just unbold the hoses and thats it. It won't conflict with the heating will it??
many thanks,
F. Nijen Twilhaar
Old Nov 21, 2010 | 08:15 AM
Don Neff's Avatar
Nope. Heat & Defrost will still work as normal.
Old Nov 21, 2010 | 10:10 AM
one more thing does the fuel cooler not work on the airco system or is it all of the same system.
Old Nov 21, 2010 | 01:48 PM
EcbJag's Avatar
The smog pump would be on the right side of the engine and easily visible (in line with the a/c compressor) if you indeed had one. And I am not sure if this is the case with an 83 but I seem to have some recolection that the a/c compressor has something to do with the auxiliary electric fan coming on? Maybe someone else could chime in on that?
Old Nov 21, 2010 | 06:28 PM
Brian Felts's Avatar
I removed mine.........the car is my daily driver and I removed mine. No problems with the electric fan. I bypassed my fuel cooler with a good set of clamps and fuel line. I have had no problems and the car is so much easier to work on.
Brian Felts
www.southernohioauto.com
Old Nov 22, 2010 | 07:57 AM
Don Neff's Avatar
Default Removing Freon Compressor
> The smog pump would be on the right side of the engine ...
A Euro spec car has an idler pulley there instead. It can be left in place.
> ... compressor has... to do with the auxiliary electric fan coming on?
All Jags are wired such that the aux fan comes on by engine temp.
Some were also wired to turn on with the A/C clutch too. Removing the compressor will not affect normal operation of the aux fan.
To remove the A/C compressor:
Cut the drive belt and remove it.
Remove the wires from the compressor clutch.
Unscrew the HP line at the condenser fitting.
Unscrew the LP line at the fuel cooler.
Remove the cruise control belows and cap its vacuum source.
Remove two mounting bolts at the bottom rear of the compressor.
Remove two mounting bolts at the bottom front of the compressor.
Lift up the compressor and the attached hoses and take it out.
You'll now have less weight plus improved access to plugs A1, A2, B1 and B2.
Old Nov 23, 2010 | 05:26 AM
Thanks to all!
Don neff I wil follow your explanation to the dot. What should I do with the fuel cooler where is do I place the line to bypass it? Many thanks much appreciated.
Old Nov 23, 2010 | 08:17 AM
Don Neff's Avatar
Default Fuel Cooler
I'd leave the fuel cooler in place. It will not harm anything.
Just disconnect the LP hose to the compressor and leave the other A/C hose connected. That hose is really hard to disconnect at the firewall without damaging something.
Old Nov 23, 2010 | 01:25 PM
Don Neff & All
I have done it taken off all the hoses and the compressor, took me only 1,5 hour. it is unbelievable but i found out that the first bougie on the left side never been connected no wonder the engine shaked. Now i have all 12 working and a beautiful place where after cleaning the mouse po and crude oil there is a beautiful engine.
thanks again.
Old Nov 24, 2010 | 11:39 AM
Sandune's Avatar
I removed my compressor because the AC was non functional and it was in the way while I replaced the plugs and injector hoses. Aside from having no air conditioning in Florida, the only problem I had was a vapor lock during the hottest day of the year, about 101 degrees F. I got a bag of ice and laid it on the engine for 30 minutes.
Old Nov 24, 2010 | 02:31 PM
brilliant Sandune, as we are talking ice and food i warmed a can of tomato soup on the right exhaust when driving it to the netherlands last winter worked as a treat.
Old Jan 10, 2011 | 10:22 AM
Pete's Avatar
Default 1989 5.3 can i remove the lot
just been looking at this thread .because I'm in the UK iv never needed the air con on any car, so (by the way mine doesn't work),i like the idea of removing the air con completely, it seems the logical thing to do.less weight, one less belt to drive, more room,and got to be good for the spark plug removal,am not to sure on how much and how far i can go without compromising the rest of the car. ie, can i get rid of the radiator(compressor i think its called) that is in front of the normal radiator. My heater only blows cold air no mater wot the setting is on but I'm led to believe that the two are not related in any way
Old Jan 11, 2011 | 11:15 AM
Pete,
I have taken my Arco pump ect off without any problems. For now i left the radiator and condenser in place. I also left the hose that goes from fuel cooler to fire wall (reason is that it is very hard to reach) Follow the steps above the one's from Don Neff and there should not be any problem. I'm taking the rest off now since I have a new engine to fit. let us know how it went.
Gr,
F.J.W Nijen Twilhaar
Old Jan 11, 2011 | 11:17 AM
Ps there is no problem with the heating it will work fine. it does sound that you need to leak at your heating matrixes (if i'm correct).
gr,
Old Jan 11, 2011 | 11:21 AM
Sandune's Avatar
Pete, you should be getting heat all the time since your air conditioning isn't functioning. There is a valve on the firewall exactly centerline of the engine. It may not be working. You can either change it out with a jag part or find a better one from a different car that will fit the same hose size. Some people have relocated theirs to a more accessible area, it is very difficult to get to behind the engine. I just put on a manual ball valve from the local hardware store. I turn it on in the winter and off in the summer.
