Removing Door Sills Preparing to weld in Floor Pans
Old Jan 3, 2016 | 08:12 AM
gthawk1's Avatar
Default Removing Door Sills Preparing to weld in Floor Pans
Good morning all! Since my carpet is my main structural member , I am preparing to weld in a driver's floor pan, and, a passenger patch in my convertible. How do the door sills come out? In a junkyard, I pried both sides up, the door sill came right out. Is this the proper way? I noticed that it didn't really snap in afterward, it just laid on top of where it should go. I also noticed that the carpet underlayment is glued pretty tight. Just scrape it away? Can it be, should it be re-used? Any advice? Thanks.
Old Jan 3, 2016 | 02:28 PM
baxtor's Avatar
I assume you mean trim plate on top of sill at door entry.
It does just pry up but can have a good grip. If it is not clipping back in it may be possible you have displaced the "clips" in the underside. They need to be evenly spaced and they can slide along the channel and all end up at one end or even fall out if the plastic end cap is removed.
Old Jan 3, 2016 | 02:51 PM
gthawk1's Avatar
Thank you, that's what I want to know.
Old Jan 6, 2016 | 11:03 AM
ronbros's Avatar
cant find pic of before change to newer sill plate (old one plastic ugh), this is what i installed,, fit perfect 1978 XJS.
Attached Thumbnails Removing Door Sills Preparing to weld in Floor Pans-jag-door-sills-before-after-003.jpg
stefos60
Jan 19, 2016 03:52 PM
stefos60
Jan 10, 2016 07:00 PM
michaelodonnell123
Jan 2, 2016 07:59 PM
grahamuk33
Dec 30, 2015 03:08 PM
