Replacing Brake fluid
Old Jul 29, 2010 | 08:50 PM
El Gato's Avatar
Default Replacing Brake fluid
Has anyone heard of replacing the brake fluid in facelift models due to corrosion?
Old Jul 29, 2010 | 08:52 PM
Doug's Avatar
I haven't heard of that specifically....but the brake fluid should be replaced every 2-3 years on general principle anyway
Old Jul 29, 2010 | 08:53 PM
El Gato's Avatar
as an additional comment, mine is a 1996 6 cylinder convertible.
Old Jul 29, 2010 | 08:54 PM
El Gato's Avatar
Thanks Cheers. I always thought replacing brake fluid was like changing the air in your tires... evidently not. Thanks again.
Old Jul 29, 2010 | 08:58 PM
Bubberstone's Avatar
Hey Doug
Me being a newb, what is the best technique/procedure for changing out the fluid? Can you just bleed it off one wheel?
Old Jul 29, 2010 | 08:59 PM
Doug's Avatar
You'll never see the recommendation in the manual for a USA made car
However, Euro, UK, and Asian cars have had the recommendation for decades
Old, contaminated fluid boils more easily...and that's bad. Plus, brake fluid absorbs moisture which is bad for the hydraulic system and further lowers the boiling point.
Old Jul 29, 2010 | 09:00 PM
Doug's Avatar
Originally Posted by Bubberstone
Hey Doug
No, bleed it off all four.
Old Aug 17, 2010 | 11:32 AM
nader's Avatar
You'd need to take the fluid from the reservoir first. Then put some new brake fluid in. Then bleed each caliper, some calipers have two bleeding points actually. Make sure no air bubbles get in while bleeding. To accomplish the no air bubble entering the caliper put a container with clean brake fluid and take a hose from the caliper nipple to the container and keep it in there at all times.. If need you more thorough explanation let me know. Also one way to bleed is to have someone pump like three times the brake then keep his foot on the brake while pressing down while you bleed the caliper. You need to do this until you see the clean oil coming out into the container..
JarodL
Mar 7, 2024 01:39 AM
Sprayall
Sep 3, 2015 07:49 PM
laserguy
Sep 3, 2015 02:02 PM
pnwrs2000
Sep 3, 2015 11:55 AM
XJsc-guy
Sep 2, 2015 11:43 AM
