Replacing Oil Pressure Sender
I drilled holes through my pedestal so I could stick extensions through it, comes out easy. Even then I like pulling the sender using a crows foot.
Make sure your replacement is right. I recently bought one that turned out being metric thread, not even close to fitting.
l have a couple of home made crows feet for the job. One for sender and the other for the small cast manifold it screws into. You will have an issue if you don't use a backing spanner.
What is a "backing spanner"?
The use of a second tool to ensure the undoing torque does not put a load on the aluminium casting the thing is screwed into. The casting can just snap off without support against the torque of undo the sender, if the sender is in tight.
