Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old Mar 12, 2021 | 05:32 AM
  #841
Rescue119's Avatar
Also picking this one up today instead. More money then the Costco brand one but it's rated the best one to get and is basically amazing. I'm gonna have to do some extra special *** kissing this weekend once I get it home. Hopefully my sons will have it years after I'm done with it
https://www.homedepot.ca/product/hus...ack/1001054247
Old Mar 12, 2021 | 01:19 PM
  #842
Rescue119's Avatar
**** ya. Been waiting half my life for something like this.
Old Mar 12, 2021 | 01:26 PM
  #843
JayJagJay's Avatar
I'm very very envious over here, as a guy who works in the streets O NYC. Congratulations, honestly! I can sense your very real excitement and it makes me happy!
Keep on truck'n, Brotha!
Old Mar 12, 2021 | 04:36 PM
  #844
Rescue119's Avatar
I've done my fair share of parking lot work back in the day. This is my first real garage. Need a shop next house lol
Old Mar 12, 2021 | 08:19 PM
  #845
89 Jacobra's Avatar
Active Streak: 30 Days
Nice Box! Pun intended.
Old Mar 13, 2021 | 01:21 PM
  #846
Rescue119's Avatar
Increased my lighting in the garage. Bought a pair of those led lights with the 4 different sections that just screw into the socket. Pictures don't do it justice but it much more brighter now.
Before
After
Old Mar 14, 2021 | 03:02 AM
  #847
Greg in France's Avatar
Link please, Rescue!
Old Mar 14, 2021 | 07:03 AM
  #848
Rescue119's Avatar
For the lights
Amazon Amazon
Old Mar 14, 2021 | 08:50 AM
  #849
Rescue119's Avatar
For the lights
Amazon Amazon
Old Mar 14, 2021 | 08:47 PM
  #850
Rescue119's Avatar
Finally finished cleaning up. Ready to start tearing apart stuff and making a mess lol
Old Mar 15, 2021 | 10:19 AM
  #851
Rescue119's Avatar
So it begins. Doing the slow drain as to not make a mess lol
Old Mar 15, 2021 | 01:59 PM
  #852
Rescue119's Avatar
Got my parts from rockauto today. Should have a few more deliveries as the week goes on.
While I waited for the coolant to drain I created my magnetic labels. Was a little more work but at least if I move things I can move the labels easily.
I only have this week to do things as I'm away next week for work.
Old Mar 15, 2021 | 08:20 PM
  #853
89 Jacobra's Avatar
That magnetic labeler looks to be a neat toy. Where did you get it?
Jack
Old Mar 15, 2021 | 09:22 PM
  #854
Rescue119's Avatar
It's not a magnetic labeler. Just a normal one. Then I bought a 15ft roll of magnetic tape 1/2.wide. Printed the labels and stuck them.on the magnetic tape. It's all from Amazon.
also got the lower and upper rad houses off this evening. What a pain as the clamps where facing the wrong way so had a hard time getting to them.
Then started taking the overflow canister off. Out of the2 nuts and one bolt/nut that hold it on, one nut came off fine, 2nd on snapped as soon as I turned the wrench. As for the 3rd well it's rusted as well but having a hard time to hold the bolt on one side and turn the nut (or vice versa) on the other side. Ugh so awkward. I need 2 heads and 4 arms I swear.
if I get to remove the rad by end of week I'll be happy.
Should I depressurize the air condition as per the ROM? It says to do it to remove the radiator.
Anything the ROM doesn't mention about doing this?
Old Mar 16, 2021 | 02:30 AM
  #855
The rad will come out without needing to touch the aircon at all.
Old Mar 16, 2021 | 05:37 AM
  #856
Rescue119's Avatar
Ok thanks. Can u think.of a reason why they would suggest it?
Old Mar 16, 2021 | 10:12 AM
  #857
JayJagJay's Avatar
Default Don't try this at home, lol
Replaced the upper most clip/holder for the linkage for the door handle release. The outer handle. Omgoodness... What a fiddly thing. How I ended up clipping it in finally was from the outside. Released what I think was a 5/16ths bolt that holds the whole handle assembly in place and then wiggled the handle around from the outside (without undoing ANY other link clips) and used a needle nose to squish the plastic clip through the hole... Was not possible with fingers.
Found this Landrover clip as a substitute replacement for the Jaguar OE part. They are exactly the same...
https://www.ebay.com/itm/264926849874
smaller space than it looks
Old Mar 16, 2021 | 10:48 AM
  #858
Rescue119's Avatar
Lol did u mean to post that here? 😅
Old Mar 16, 2021 | 01:09 PM
  #859
Rescue119's Avatar
Very productive day!
as u can see the fan has been rubbing. So plan is to replace it with electric. I'll be asking about that once I'm back to this point someday lol
it all came apart fairly easy. I'll need a new expansion tank as its rusted pretty bad. Might go aftermarket.
I also forgot that the transmission fluid goes to the rad for cooling and I took off those pipes and nothing game out. Then after a minute u hear the fluid coming out. Saw the tranny fluid and panicked for a second lol
The bottom cross beam.... where the rads sit in. Is that easy to take off or am.i gonna have to remove the a/c rad as well? It pretty rusted. It's just surface rust but I'd like to take it off and give it a proper cleaning.
The bottom rad mounts were rough shape so will be replacing those.
The fins on the rad look pretty decent once I cleaned up the junk. Hopefully I can get it refurbished.
I took the LHS air filter housing (the part that attached to the throttle housing) was a little oily and I can see some oil by the flapper.
Overall I'm happy with my progress. Only 2nd day and rad is out. I thought I would be doing this by Friday.
tomorrow's plans are to take the Fan off, and then get the belts and air pump off. I'm removing emission stuff. I've found some posts but nothing super clear on what houses to run. My goal is to put a new alt where the air pump was and have electric fans so.i am.down to only 2 belts.
Also ripped my work pants so gonna go get some coveralls I think now that I am done early lol.
Thanks for the continuing help everyone.
Old Mar 16, 2021 | 02:30 PM
  #860
Rescue
Oil inside B bank air filter housing is normal, it is a result of the crankcase ventilation going through that air box.
The beam under the rad is a structural welded-in item, part of the monocoque. It has to be repaired in place. All it looks like needing is a blast of cavity wax (eg Dinitrol) into the inside, and a good cleanup and anti-rust paint on the outside. If there is an actual rust hole, then weld a thick plate over it, having ground the area back down to bare metal.
Is yours a Lucas or Marelli ignition?
