Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old Jul 6, 2021 | 07:13 PM
  #1001
Xjeffs's Avatar
Default Next
Originally Posted by Rescue119
After
that looks great. I just sent you mine.
Old Jul 7, 2021 | 01:57 AM
  #1002
Dukejag's Avatar
Yep - looks real good, this is the fun part making things look new or better than new!
The plated parts that were gold can be replated very cheaply and will look new.
Whats next...
Old Jul 7, 2021 | 05:38 AM
  #1003
Rescue119's Avatar
haha thanks
Old Jul 7, 2021 | 05:40 AM
  #1004
Rescue119's Avatar
Whats next...
I have to tap the holes the air rail feed into the intake next before I start putting stuff back in the V. Then next is the cruise control bellows and bracketbracket.once that's back in the V I can start working on Then intake manifolds and fuel injection system.
Old Jul 7, 2021 | 06:46 AM
  #1005
Thorsen's Avatar
When I did mine, I tapped the holes to 5/16-18 and used screws like this with thread sealant to close off the ports.
It's best to do it when the manifold is off the engine. I would do it on the car if it was a do-or-die situation but since you have the manifolds off there's no better time like the present.
Old Jul 7, 2021 | 06:57 AM
  #1006
Rescue119's Avatar
Yep exactly the size and screws I'm using and with the tread sealant.
I've done one I'm just waiting for the screws to show up to make sure i have the right depth so I can mark my tap before I do the other 11.
Old Jul 8, 2021 | 02:54 PM
  #1007
Rescue119's Avatar
Switch came in. Put the new coil on. Ready to go back into Vee
Old Jul 8, 2021 | 09:48 PM
  #1008
89 Jacobra's Avatar
Active Streak: 30 Days
Looks good for another Hundred Thousand Miles.
Jack
Old Jul 9, 2021 | 08:20 AM
  #1009
Rescue119's Avatar
Jack
I dont think I've every owned a car long enough to out 100k on it lol. I think my minivan will be the first but I still got 60k to go.
plan is to have it for my sons 16th birthday in 13 years time.
Old Jul 9, 2021 | 12:24 PM
  #1010
Rescue119's Avatar
So just redoing the cruise control bellows and I've read there's some silicone that needs to be applied to the inside lip.
When I took mine apart there was no sign of silicon being used. It was the orginal bellows.
So do I dry fit it or find some silicone for it?
my ref
https://www.jaguarforums.com/forum/xjs-x27-32/how-cruise-control-repair-120863/
Old Jul 9, 2021 | 10:46 PM
  #1011
Rescue119's Avatar
My grub screws showed up. Got one in. Worked great. So now to do the other 11 lol.
Old Jul 10, 2021 | 01:22 AM
  #1012
Greg in France's Avatar
The silicone is there to help contain the vacuum in the bellows, IF, repeat IF, the rubber of the beloows has hardened a touch and it will not, on its own, hold vac. If the CC works Ok without silicone, all good. If it does not apply silicone to help the bellows seal.
Old Jul 10, 2021 | 06:24 AM
  #1013
Rescue119's Avatar
Ok thanks. It's a new bellows so it's flexible. The old one was definitely not.
Old Jul 10, 2021 | 01:53 PM
  #1014
Rescue119's Avatar
Bellows on, set screws in,
Recounted the a/c compressor
Old Jul 10, 2021 | 06:11 PM
  #1015
Rescue119's Avatar
The Vee getting full again lol
Now onto this mess
Old Jul 12, 2021 | 03:45 AM
  #1016
Dukejag's Avatar
Have you converted to a single coil?
Old Jul 12, 2021 | 04:37 AM
  #1017
Rescue119's Avatar
Well i couldn't find the 2nd coil even though I had the round one but yes I have the square one now as recommended. Scroll up and you will see it.
Old Jul 12, 2021 | 06:45 PM
  #1018
Rescue119's Avatar
Just about finished the FI harness. I promise it will look neat once it's installed lol.
Old Jul 13, 2021 | 01:38 AM
  #1019
It should be on the apron in front of the radiator grille.
Old Jul 13, 2021 | 01:40 AM
  #1020
Dukejag's Avatar
Holly molly - that is some good work.
What / how did you do that?
Is there a nice simple drawing us simple men can follow?
Next winter... love to build one.
