Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old Oct 8, 2021 | 03:09 PM
  #1081
Greg in France's Avatar
Originally Posted by Rescue119
new fuel hoses run. Only part not connected is the end going to the fuel cooler. I'll wait to that's back in place before I cut the remaining hose to length
Rescue
The hose you have repaired running from the fuel rail down to the B bank FPR does not look like the OEM one, in as far as the OEM one on my car has a much longer metal section. This is the oEM one on my car:
I only mention this as I believe the least amount of rubber hose downstream of the injectors to the FPR, the better the throttle response.
Now I may be quite wrong about that point, but I am interested to know if the OEM part you replaced was different from mine?
Old Oct 8, 2021 | 03:12 PM
  #1082
Rescue119's Avatar
Rescue
I replaced that whole section with one piece of hose. Same as the the fuel in on the other side. Replace 2 sections of a mix of hose / pipe with one piece of hose.
I'm not sure if that's true. If it is I can swap it out for the orginal.
I'm not keeping stuff oem/original.
Old Oct 8, 2021 | 03:17 PM
  #1083
Rescue119's Avatar
The circled piece is actually from the RHS FPR (I deleted that one) but needed to connect to the FPR.
Old Oct 8, 2021 | 03:18 PM
  #1084
Rescue119's Avatar
Old Oct 11, 2021 | 06:27 PM
  #1085
Rescue119's Avatar
Gave the Lucas module a fresh paint.
Coming together. Also started going over my re hooking up plan. Checked all my labels and so far everything seems to be going in the right place lol.
My knees been bothering me but I need to get under and take the alt off.
Old Oct 16, 2021 | 10:05 AM
  #1086
Rescue119's Avatar
Got my alternate out this morning
So because I'm going electric fans and removed the air pump which the new alt will go, I feel there is more of this I can remove. I just want to know which parts?
I'm thinking I can remove the idler and the stock fan wheel. Stuff circled
Old Oct 16, 2021 | 12:39 PM
  #1087
Rescue119's Avatar
So found the sticker. I have the 115 alt.
Dropped of for a rebuild.
Old Oct 22, 2021 | 04:45 PM
  #1088
Rescue119's Avatar
Got the alt back today. Looks great
Old Oct 23, 2021 | 11:20 AM
  #1089
Rescue119's Avatar
Spark plug wires, tb connections, cruise control cable, and some air lines hooked up this morning
Old Oct 24, 2021 | 06:15 AM
  #1090
Rescue119's Avatar
Started the wiring. Was gonna put it in wire loom but when I got near the front 1/2 inch loom wasn't enough. So ordered 3/4 inch loom. To be continued...
Old Oct 24, 2021 | 08:06 AM
  #1091
ptjs1's Avatar
Rescue,
Sorry, what does "1/2 inch loom" and 3/4 inch loom" mean? Is that the sheathing size or something else?
Tks
Paul
Old Oct 24, 2021 | 08:17 AM
  #1092
Rescue119's Avatar
Originally Posted by ptjs1
Rescue,
Tks
Paul
this is wiring loom. Covers the wiring to protect it and organize it. Because I went with thicker silicone wiring to replace the factory wiring 1/2 loom wasn't big enough. Almost 3/4 should do the job
Old Oct 24, 2021 | 11:54 AM
  #1093
R escue
Over this side of the pond, "loom" refers to the entire wire bundle, and what you call loom we would call loom wrapping, or loom cover, or some similar name.
Old Oct 24, 2021 | 04:21 PM
  #1094
Rescue119's Avatar
R escue
Got ya. Same same but different.
Hey Greg did you see my question in post #1086. About the idler arm removal?
Old Oct 25, 2021 | 12:35 AM
  #1095
Rescue
If that idler (the one with the studs) is the fan bearing casting for the old mechanical fan, and if the belt that drove them is not being used for anything else, then the lot can be removed. You will find that when removed, the fan boss casting is on top of part of the water pump housing; and that the studs that held both are not threaded enough to tighten the water-pump-only thickness. I just used thick spacers on the studs, but you could tap it further down and use less thick spacers. Some people remove the stud and replaced it with a bolt - but I did not want to for fear of breaking the stud. Pic attached of what I did, which I blush to publish - at the time I had to improvise and until now I forgot all about them - but the spacers have worked for 20 years!
Old Oct 25, 2021 | 04:43 AM
  #1096
Rescue119's Avatar
Rescue
Awesome thanks this helps a lot.
Old Oct 25, 2021 | 02:34 PM
  #1097
Dukejag's Avatar
Looks really - good.... great job, have you got lost with what goes where?
That would worry me a lot.
Next winter - it will be my turn, I will be following your post.
What did they do to the alternator?
-Rewire and bearings?
What do they charge for that?
Old Oct 25, 2021 | 03:55 PM
  #1098
Rescue119's Avatar
Got the new loom today. Much better due to the 16g wire compared to the shitty 18g brittle stuff. Still playing with routing but at least I don't have 24 wires everywhere.
2nd photo shows the cross pipe for the coolant system. It's pretty rough on the outside. I'll have to clean it up and inspect the inside. I did find a post about making a replacement out of copper piping with an improvement. Might try that because why not lol
Going to pick up my new 2dr Jeep ****** edition tomorrow. Suppose to rain but I'll try to get some pics
Old Oct 26, 2021 | 06:25 AM
  #1099
Rescue119's Avatar
Missed this post somehow.
For the harness I basically followed each wire from the original harness. Also labeled lots with painters tape. I dont remove the labels until I put it an item back in place. I also printed out expanded parts diagrams from sng barret to keep track.
Double and triple check. Still gonna be nervous when I eventually turn the key since I've done so much. This image is super helpful.
as for the alt it was completely rebuilt. Basically brand new bearing etc. cost was 180cdn with is about half the cost of a new one at 115amps.
My time is mostly spent cleaning and refurbing. Replacing the parts is the easiest part of the whole thing lol
Old Oct 26, 2021 | 04:47 PM
  #1100
Rescue119's Avatar
Brought a new hobby home today lol
