Rust!!!
Old Oct 19, 2010 | 09:14 PM
Bubberstone's Avatar
Default Rust!!!
I was sickened to see some surface rust in the top left corner seam of the trunk (in between the rubber seal and the bodyalong the weld seam).
Should I take it to a body shop to have the problem fixed as soon as possible or is this a lost cause now
I have not seen any other sign of fruct on the car to date but I now wonder if this is the end!
Old Oct 20, 2010 | 07:23 AM
Sarc's Avatar
All cars are going to rust at some point (apart from those new fangled ones made out of recycled drinks cans / aluminium)
One thing is for sure that it won't get better on its own, but at the same time it doesn't sound like its the end of the car just yet. Have a professional bodyshop look at it and the rest of the car while it's there. Then go to another bodyshop to get a second opinion. You could be looking at a little bit of surface rust that just requires treating and repainting, or this could be the beginning of something a lot bigger.
What year is the car ? Any other signs of rust in other places ? Has it been a dry state car or a wet state car ? Any previous bodywork done on it that you know of ?
Old Oct 20, 2010 | 08:42 AM
Its an 86. No other rust (I have seen) and I am in a relatively dry place. No body work I am aware of either.
Old Oct 21, 2010 | 01:52 PM
Sarc's Avatar
I suggest you get it fixed then
Old Oct 21, 2010 | 02:39 PM
alexsneesby's Avatar
Like the others said I certainly wouldnt wait. Ive had some areas like that and it turned out to be a little surface rust and it just needed grinding, treating and repainting. However it could be bigger, but its not the end of the world.
Even if they have to cut a section out and weld in a patch, the price shouldnt be too bad. Plus its better than letting the cancer spread.
Old Dec 9, 2010 | 05:16 AM
rocketlift's Avatar
Did you go for it in the end Bubberstone?
Old Dec 10, 2010 | 09:56 AM
Was going to take the car in but weather here had another plan....that is it dropped to -10 and started snowing.
Have put the car in storage for the winter so will have to tackle this in the new year(April)
Old Dec 10, 2010 | 12:03 PM
rocketlift's Avatar
Ok thanks. Well, let us know what happens. The way time flies April will soon be here.
Larry-Cleveland
Feb 9, 2019 03:17 PM
Johnken
Apr 8, 2018 10:21 AM
prettydaim
Nov 12, 2015 08:05 PM
bdboyle
Nov 6, 2015 02:07 PM
jospolice
Oct 1, 2015 07:52 AM
