Seat position Memory
Old Aug 19, 2017 | 02:33 PM
tomtomterrific's Avatar
Default Seat position Memory
Guys:
I have a 94 XJS 6
The seat adjusters work.
So do the heated seats.
The lumbar motor works though I don't feel any "adjustment"being made, is this an air bladder?
The seat memory doesn't work. Any tips on what to check first?
Thanks,
Tom
Old Aug 19, 2017 | 05:30 PM
warrjon's Avatar
The lumbar is an air bladder and what I have seen is the hose from the bladder to the pump deteriorates and falls apart. It is a pain to replace as the hose is swagged into the bladder.
I removed my hose and replaced it with a bit of vacuum hose, I slightly tore the entry to the bladder and had to seal it up with Polyurethane sealant and a cable tie.
Seat memory I would check connectors and seat position sensors, you will have to remove the seats to get at the sensors, my car does not have power seats so I can not help you with where the sensors are but they will be there.
