Should my clutch feel like this?
Old Jul 13, 2019 | 07:34 AM
leep123's Avatar
Default Should my clutch feel like this?
Hi everyone,
Car is a 1990, 5 speed manual with the 3.6 engine. I have just replaced slave and master cylinders and fully bled system after experiencing severe clutch drag. Both units were faulty especially the master cylinder (see separate posts).
I think my hydraulic system may have been failing for some time so I am not quite sure what a normal clutch should feel like on one of these cars. Difficult to measure exactly but my clutch pedal starts to bite about 1 inch above the floor and is fully engaged by about 60% of the full pedal movement. At rest the clutch pedal sits just slightly below the brake pedal.
The short travel distance between the clutch starting to engage and being fully engaged makes for a slick, smooth and quick change and everything seems to work fine with no resistance or crunches on the gear lever between changes. However, is this clutch behaviour normal for these cars? Would be really interested to hear from others with similar transmissions so I can judge if I have a 100% fix. All other comments welcome.
Thanks for reading.
Cheers,
LeeP
Old Jul 13, 2019 | 11:56 AM
Greg in France's Avatar
Quite normal. Well done.
Old Jul 13, 2019 | 03:43 PM
leep123's Avatar
Thanks Greg. Took my 125k, Volvo 940 estate out today for the first time in a month. Have never really observed the clutch pedal travel before but seems very similar to the XJS.
Cheers,
LeeP
Unhingd
Jul 28, 2016 11:24 AM
Canard
Apr 9, 2014 07:51 PM
David's XKR
Jun 21, 2011 09:20 PM
lcyoung
Nov 11, 2008 09:12 AM
nineball
May 25, 2007 02:03 PM
