slight hesitation on acceleration
Old Mar 10, 2015 | 03:56 PM
kenr's Avatar
Default slight hesitation on acceleration
I have a 1996 4.0 liter xjs convertible with 135,000 miles. I noticed that when the car is parked and I step on the gas pedal there is a slight hesitation but then it seems to run fine while driving. Any ideas where I should look first. Thank you for any help you can give.
Old Mar 16, 2015 | 04:07 PM
Jonathan-W's Avatar
When was the last time the air cleaner was changed...?
Old Mar 16, 2015 | 09:49 PM
superchargedtr6's Avatar
I would think that the TPS has gotten a little worn, maybe sending bad signal like a flat spot.
Old Mar 17, 2015 | 09:31 PM
kenr's Avatar
About six months ago, less than a thousand miles on new filter. Thanks for your input.
Old Mar 17, 2015 | 09:36 PM
kenr's Avatar
This is the second time someone mentioned the TPS, I will be looking into that, thanks for the tip.
Old Oct 17, 2016 | 01:38 PM
Hitch's Avatar
Did you resolve this issue?
jimforrest (uk)
Feb 28, 2019 06:42 PM
Inspector
Oct 17, 2015 12:51 PM
mat32essex
Oct 3, 2015 04:12 PM
Poet
Oct 2, 2015 09:00 AM
