Smell of fuel in the boot
Old May 7, 2019 | 02:31 PM
brinny's Avatar
Default Smell of fuel in the boot
Evening all, I had the fuel tank re sealed and repaired at Xmas. I have re connected everything a couple of months ago and am sure there are no leaks. Despite this I am still getting a smell of fuel in the boot. Any suggestions to possible problems or solutions please. Many thanks in advance.
Old May 7, 2019 | 03:04 PM
leo_denmark's Avatar
In my case the smell came from leaking steel line over the IRS
Old May 7, 2019 | 03:40 PM
brinny's Avatar
Those pipes are new as well. It seems to be coming from the filler cap area.
Old May 7, 2019 | 03:57 PM
Time-Pilot's Avatar
How is your pressure at the fuel cap after a drive?
Old May 7, 2019 | 04:32 PM
warrjon's Avatar
Have you checked the vents, they are on the RH side of the tank at the top.
Old May 7, 2019 | 07:54 PM
BradsCat's Avatar
Mine got some gas into the foam backing of the rubber mats. I washed them but still the odor is there although not nearly as bad as it was.
I probably should have replaced the mats when I replaced the gas tank two years ago.
Old May 7, 2019 | 11:12 PM
brinny's Avatar
I
I haven’t driven the car. It has been on axle stands for some time undergoing restoration work.
Old May 7, 2019 | 11:14 PM
brinny's Avatar
I don’t recall any vents on the tank warren. There is a small hose as I remember going from the tank to the filler cap if you mean that?
Old May 7, 2019 | 11:38 PM
Brewtech's Avatar
Evap system always comes to mind, but not sure if you have one.
Old May 7, 2019 | 11:55 PM
brinny's Avatar
I don’t think I have. It’s an 89 v12 convertible. Tank is slightly different to a coupe I think?
Old May 8, 2019 | 12:27 AM
Spikepaga's Avatar
If the sender unit was removed, it is possible the gasket was not replaced or is too old.
Old May 8, 2019 | 01:02 AM
Greg in France's Avatar
Brinny
Which of the many pipes inside the boot did you renew, as well as sorting the tank?
Just a few ideas:
It would be worth taking a very careful look at the filler flexible. This is not easy to connect properly and tighten
Did you use new olives on the connectors into the boot?
If all else fails, then block the inlet and outlet pipes and all the others except one, and pressurise the tank using a radiator pressurising gizmo from some pipe or other and see where it weeps/hisses etc.
Old May 8, 2019 | 07:43 AM
ptjs1's Avatar
brinny,
You didn't mention which of your cars is having the problem? IIRC, the 4 litre facelift setup has 3 flexible hoses on the top of the tank. The one that is the most inaccessible has a tendency to collapse and deteriorate which can cause fumes in the boot.
Good luck
Paul
Old May 8, 2019 | 10:07 AM
Noah's Avatar
Lots of possible sources for the smell as indicated by the various responses. I'd invest in a fuel sniffer like the Tif 8800 to help isolate the source. Very useful and time-saving tool and you can get them used off of ebay for $50-$80. I used one on my XJS to trace the fuel odor source to a wiring bodge through the evaporative flange on top of the tank. Good luck.
Old May 8, 2019 | 12:04 PM
ronbros's Avatar
also , i have had many different makes of cars,, and ALL of those with the tank located INSIDE the car body always had some fuel oder! (of course there are exceptions)
the cars with tank and associated parts located outside the body, had little to nothing for oder!,,(altho they had other problems,like crash fires,minor stuff tho LOL.
ron
Old May 8, 2019 | 12:11 PM
ptjs1's Avatar
brinny,
apols, just noticed that you were talking about your 89 convertible.
Paul
Old May 8, 2019 | 02:48 PM
brinny's Avatar
Thanks for all the replies, I will dig deeper. All hoses were renewed when the tank was replaced and I will indeed check the filler hose connection Greg. I feel it is in that area my problem lies. Once more thanks lads.
Old May 8, 2019 | 04:42 PM
BradsCat's Avatar
I suggest taking the tank out. the car s 30 years old. If it ever had moisture in the trunk (boot) and it got under the tank it could deteriorate it over time.
All kinds of hoses and connectors associated with these cars.
Two additional potential sources are the fuel sender unit locking ring not being fully seated and the fuel filter clamps. Also check the 'expansion tank' and hoses located under the battery on my '87
Old May 8, 2019 | 08:22 PM
mghirsch's Avatar
In my case, I was getting seepage from the sending unit. Not the gasket and locking ring, but the actual sending unit.,
Old May 10, 2019 | 08:10 AM
JayJagJay's Avatar
There is a "gator" right at the top of the filler neck. It is fragile (mine was after years of sitting) and I would imagine that part of resealing the tank would very well have disturbed the gator, fuel cap, fuel tank connection... It is ribbed/accordion style and a leak in this is not always easy to see. Ya can't get your eyes around the entire circumference to check.
What might help checking is to undo the bolts/screws that hold the gas cap to the body, undo the clamp (in the boot) that secures the gator to the cap assembly, remove the cap and then inspect the gator cap assembly seal from outside the car/boot.... Just my 2cents...
