Socket or tool used to unthread manual transmission inspection bolt/Nut?
Old Jun 12, 2017 | 03:04 PM
Jim Vranich's Avatar
Default Socket or tool used to unthread manual transmission inspection bolt/Nut?
I am performing some basic maintenance on my 93 XJS 4.0 with 5 speed. I want to check the Manual transmission's fluid level. I'm seeing and odd looking nut that has an unusual socket inset. It looks like a special tool is needed to unthread the nut. What do tool do I need to remove the nut so I can check this manual transmission's fluid level?
Thanks, JV
Old Jun 13, 2017 | 06:57 AM
Socket or tool used to unthread manual transmission inspection bolt/Nut?-jag-manual-trans.png
The fill pug is #5 and JLM1180 is the part number.
It will be either allen key (6 sided hex) or Torx (star shaped).
I have no idea which it is, but I would guess at Torx.
Old Jun 13, 2017 | 02:57 PM
Yes, an allen wrench or Torx appear to be the correct tool to use but the hole is far larger than any allen or Torx wrenches I have. I guess I'll have to see if my parts store has a tool large enough. Thanks. JV
