Solar Trickle Charger
Old Aug 4, 2021 | 09:20 AM
inertian's Avatar
Default Solar Trickle Charger
Have two corded battery maintainers/trickle chargers, bought this one for when I travel and want to top off the battery.
Tests fine (up to 20v in bright direct sunlight) but when I attach to battery, the battery voltage measurement keeps decreasing. Not sure if the charger can't keep up with some (yet undiscovered) parasitic draw or I just bought the wrong item.
To clarify, my typical test procedure would be:
  • Position solar charger for maximum sunlight capture via meter test (usually16v or more)
  • Open trunk and attach clamps to battery terminals
  • Close trunk gently to avoid pinching wires
  • About 15 minutes or more later, open trunk and meter battery
Typical measurement would be 12.9v at start, 12.6v at test
Opinions?
Old Aug 4, 2021 | 10:41 AM
RickE's Avatar
Could it be that your trunk lights are staying on and overpowering the output of the charger? I use a trickle charger on my cars and have removed the fuse for the trunk lights to avoid that problem.
Old Aug 4, 2021 | 10:51 AM
inertian's Avatar
Thanks, I will check that. I know there is a way to trip the trunk latch such that the lights go out, but pulling the fuse will work too...
bjmawg
Aug 26, 2021 07:59 AM
JDog
Jul 8, 2021 11:04 AM
tanngo
Sep 13, 2014 05:41 PM
abela
May 21, 2013 11:48 AM
lafrm
Canada
Jun 2, 2012 09:56 PM
