Source for 88 HE springs
Old Apr 15, 2009 | 07:15 PM
JagtechOhio's Avatar
You can remove the rear shock and spring assemblies without much drama, and you will need a tool to compress the spring to remove the retaining collets. Any sort of McPherson strut spring compressor tool from the rental tool shelf at a local parts store will work.
The front springs are an entirely different story.
It can be done relatively easily with the factory tool or a fabricated substitute. It is extremely difficult to do without. The short expanation is that the corner weight of the car is not great enough to compress the free length of the spring to the extent that the spring pan can be refit. You jack up under the spring pan, and all you are doing is pushung the car towards the sky once the spring is partially compressed.
SD96XJ6L
Dec 27, 2025 09:58 PM
multistrada74
Oct 8, 2015 08:58 AM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
Bcrary3
Sep 27, 2015 12:21 PM
