....source of de Nile?
Old Sep 3, 2019 | 09:58 PM
anyoldiron's Avatar
Banned
Default ....source of de Nile?
..........................or just Mark in denial.
lve been looking for my passenger footwell water source on my 1982 XJS FHC V12, ive cleaned out the scuttle and also the evaporator drain tubes. lt seems that the water has been coming down the inside of the bulkhead where the rust streak is. The question is is this typical of either blocked scuttle or evaporator pipes or do i need to keep looking?
Cheers AOI
Old Sep 3, 2019 | 11:08 PM
VancouverXJ6's Avatar
Place garden hose on top of car, sit in side with can of beer, carpets removed....and wait. Depending on the result you'll eliminate half the possibilities.
I'd also look into getting a jug of corroseal and grirty sand paper fo clean that up after.
Old Sep 4, 2019 | 01:09 AM
Greg in France's Avatar
I would say that, as well as the blocked aircon, that has been coming in past the windscreen seal. The only way to be sure is to remove the dash and the aircon unit and look, treat, repaint and seal the windscreen and any other areas you find.
Old Sep 4, 2019 | 09:18 AM
anyoldiron's Avatar
Banned
Thanks Greg! The second sentence, that will be the aforementioned denial then. LMAO. l was thinking at the very least to do the job properly the screen has to be refitted with a new seal and then if that isnt a fix the dash has to come out.
lm going to currently take the cowards way out and not let it in the rain. unless testing.........
Old Sep 9, 2019 | 10:25 AM
anyoldiron's Avatar
Banned
100% Greg. lts been raining so its showed its hand....................again. The windscreen rubber is shagged but i might have to replace the windcreen so i will hold of on this one. Thanks again!
orangeblossom
Jan 28, 2019 12:33 PM
J_C_R
May 18, 2017 01:33 PM
haroldpeacocksr
Aug 20, 2016 01:55 PM
XKJoe
Jan 25, 2016 04:49 AM
Maninahat98
Jul 17, 2013 12:43 PM
