spacers
Old Mar 13, 2015 | 09:43 PM
drbill's Avatar
Default spacers
Okay, all you guys running XK8 17x8 wheels with ET33, looks like you are using a spacer on the front. In reading the forum here, I've seen 1/4" and I've seen 13mm. Can you tell me where to get these spacers?
Is this an option?
Billet Hub Centric Wheel Spacers Jaguar (Pair)
Would this require longer lug nuts?
Old Mar 14, 2015 | 05:18 AM
Brake buster's Avatar
yes
hub centric spacer on the front only , i actually use a 25mm one ( 1" ) hub centric
these will have their own short head nuts which you bolt to the hub , then you use your own wheel nuts to bolt to different threaded studs in the hub centric spacer
just watch the clearance rubbing on the lower rear sill end on full lock , but this will depend on the tyre profile
they can be easily got from ebay , differing prices and possibly qualities ,
http://www.ebay.co.uk/itm/H-R-30mm-H...item25837114ab
IMG_1099 by MyPix on Talk Photography
BB
Mac Allan
Jul 20, 2020 05:46 PM
XJ8JR
Sep 29, 2015 06:59 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
metalmarty
Sep 11, 2015 07:05 AM
