Speedometer Transducer won't snug up properly
Old Nov 27, 2021 | 02:47 PM
losfinch's Avatar
Default Speedometer Transducer won't snug up properly
I’m still working on the finishing touches of the 84 XJS I acquired from my father who installed a 350 Chevy with a TH350 transmission. My speedometer wasn’t working and I discovered that there was no transducer on the transmission. I purchased one but when I go to install it I find that it fits into the “bullet” ok, the cable slips in fine and all but when I tighten up the large outer screw portion it bottoms out up against the transmission before it is able to tighten up the transducer. So the transducer is installed but with a substantial amount of play. You can wiggle it around quite a bit.
Is that normal? Is there a recommended way to fix that? Its a DAC 4569 stock transducer on a Chevy TH350 tail housing.
Thanks for any advice!
Anthony Finch
Old Nov 28, 2021 | 02:13 AM
Greg in France's Avatar
Not normal, must be fixed. I would pull the inner plastic gear and see if the square end of the driv cable is going home properly. If it is, remove the casting the transducer goes onto and assemble the thing off car and see where the play is. It might just need a spacer. I also just mention that on early HE XJSs the speedo was entitrely cable driven, so are you sure you have an electronic speedo head? . On early electronic cars the gearbox had a right-angled drive attachement on it, this converted the previous cable drive gearboxes - which could not take the transducer directly - to take electronic drive, so this might also be your problem if you have one of these versions.
Old Nov 28, 2021 | 09:41 AM
losfinch's Avatar
Hey thanks Greg for the valuable information. The engine and transmission conversion were done before I got a hold of the car so I do not know what type of speedometer adapter for the transducer was originally on the car. The transmission that was put into it uses the bullet shaped speedometer gear holder vs the larger round holder that I think would allow the transducer to connect to properly. My tail housing will not allow for interchanging of those two types but you did make me think that if I was to get ahold of one of the right angle adapters that then I could probably be able to attach the transducer correctly to that. So thanks for giving me that idea. Anyway, in the meantime yesterday I simply added a couple of small washers inside of the large screw down nut of the transducer to take up the slack and it has allowed the transducer to be attached firmly to the transmission. The only shortcoming I see is that the transducer's actual cable doesn't penetrate into the plastic drive gear quite as far..about 1/8" of an inch shorter. Mine for sure is an electronic speedometer as I have had the dashboard apart to check on it.
Old Nov 28, 2021 | 11:02 AM
Try it and see, sounds like the washer packing should do it.
Old Nov 29, 2021 | 11:10 AM
losfinch's Avatar
The transducer did snug down firmly using two small washers...problem is that the speedometer is still not functioning. So, on problem solved but I need to move on to looking as to why the speedometer doesn't work. I think I'll start with a new ground connected directly to the speedometer ground on the printed circuit board as some have suggested. We'll see.
Old Nov 30, 2021 | 01:24 AM
Check that you have 12 volts, ignition on, to the green wire that goes to the two wire loom plug in the harness that the transducer plug connects with. If so, that side of things should be OK. Also check that the other wire has continuity to the instrument binnacle multiplug. This wire sends the signal.
This is correct for my car as a binnacle identifier:
Old Nov 30, 2021 | 08:12 AM
jal1234's Avatar
That pdf is useful. Thanks!
Jon
The Mekon
Dec 27, 2022 12:52 PM
Unhingd
Feb 26, 2019 12:01 AM
Translator
Detailing / Car care
372
Feb 26, 2014 06:51 PM
muckbury
Nov 3, 2013 09:20 AM
