Steering rack rebuilt help
Old Jan 9, 2014 | 04:15 PM
MarkJR's Avatar
Default Steering rack rebuilt help
Hello guys!
I started to rebuild my dads jag and i need some help with the steering rack. It leaks and i need to change the seals. I want to know how can i open the steering tower and how can i change inner steering rod seals?
All kind of info is welcome!
Thank you!
Mark
Old Jan 9, 2014 | 04:30 PM
MarkJR's Avatar
Old Jan 9, 2014 | 07:34 PM
icsamerica's Avatar
Default Consider this.
https://www.jaguarforums.com/forum/x...-pinion-96469/
Old Jan 10, 2014 | 01:57 AM
user 652867429824's Avatar
mine as well is leaking, I went on e-bay and found the best warranty and price
Old Jan 10, 2014 | 03:41 AM
scottmg's Avatar
Default Rack rebuild
I had exactly the same problem a year ago. My XJS only had 116000 on the clock so I thought a seal kit would suffice. Unfortunately after dismantling we found the rack shaft was excessively worn. I had to have a local company hardchrome & grind the shaft then reassemble & pressure test the completed rack. Ended up being a $1000 job. Bad experience all round.
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
wichita
E type ( XK-E )
Apr 16, 2016 04:00 AM
Delta66
Oct 4, 2015 05:40 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
