Sticking tranny dipstick
Old Jun 10, 2012 | 08:45 PM
RagJag's Avatar
Default Sticking tranny dipstick
1996 XJS 4.0. Transmission dipstick will not come out. Is this a problem with the Automatic tranny? I don't want to break it.
RagJag
Old Jun 11, 2012 | 08:04 AM
JameyXJ6's Avatar
The only reason I can think of that would cause it to be stuck is if the tube was bent for some reason? There isn't much room between the tube and the firewall, but see if you can see past it with a flashlight.
Old Jun 11, 2012 | 08:21 AM
I am assuming on the 4ltr in the XJ-S it is on the LH side, just adjacent to the engine dipstick, like in my AJ16 (X300)??.
If so I would think it is probably just "stuck" on the o/ring seal that is just under the plastic bit you actually grab hold of.
It also may be that it has NOT been extracted for a looooong time and is also just "stuck".
There is NO clip, or special technique to removing it that I know of.
Old Jun 11, 2012 | 07:58 PM
RagJag's Avatar
Thanks Jamey and Grant. I will have to get a slim piece of metal and push it down into the tube past the rubber.
RagJag
Old Jun 11, 2012 | 08:43 PM
Or, just dribble some trans fluid around the top bit, and it should soak thru and lube the thing, this allowing extraction.
My V12 is a MONGREL at times, and access is ZERO, so a long hook wire, and pull like hell. One day that red plastic is going to break, so be it. I lube that thing every time it goes back, but it still sticks on the 2 o/rings. It dont leak ATF, so I dont dip it too often.
bdboyle
Sep 16, 2019 05:58 PM
adam699
Oct 13, 2015 05:53 PM
Poet
Oct 2, 2015 09:00 AM
millertic
Sep 30, 2015 08:11 PM
