strut and shock observer replacement
Old Jul 11, 2018 | 02:34 PM
Romel420's Avatar
Default strut and shock observer replacement
I'm planning on replacing my suspension on my 1988 jaguar xjs. How many struts/shock absorbers does it have ? What brand strut/absorbers you recommend ? Is there a video or images i can look to see on how to replace it. Thank you for the help.
Old Jul 11, 2018 | 09:48 PM
Daim's Avatar
It has 6 shock absorbers. 2 in the front, 4 in the rear. Original shocks are from Boge. Kayaba Gas A Just is supposed to be a good upgrade.
Old Jul 11, 2018 | 10:09 PM
Doug's Avatar
There are sub-variations/methods but here are a couple of pictorials that with give you a basic idea of the job
Front Shock Replacement
http://www.jag-lovers.org/xjlovers/xjfaq/picturefaqs/shocksandsprings/rear/index.html
Old Jul 11, 2018 | 10:13 PM
Doug's Avatar
Can't make the links work right but if you click here and go to "XJ FAQ" you'll find pictorials for both front and rear shocks in the front/rear suspension sections
XJ Lovers - FAQ's and Technical Information
Old Jul 11, 2018 | 10:51 PM
Time-Pilot's Avatar
I just did this job last weekend, it's a piece of cake (on my 4.0l). I used the following:
Front:
Gabriel 69677 $28
Rear:
SACHS 311347 $38
The fronts took about 45 mins to do and the rears about two hours because you have to compress and remove the coil springs then put them back on like a normal strut on spring car.
Old Jul 11, 2018 | 11:34 PM
Daim's Avatar
Front replacement is easy. Und the top nut in the engine bay, undo the screw in the bracket behind the wheel and then lift the body. They should just pop out. The rears come out as a unit with the spring (so spring compressor is required). I think you can do them still in the car but it might be easier to drop the rear subframe (not fully remove it). Basically undo the lower fulcrum shaft, undo the top bolt and it comes out. If you have a look, it is all selfexplaining
scottatl
Jun 30, 2019 08:55 AM
Xcellr8
Jun 11, 2014 09:48 AM
H20boy
General Tech Help
Oct 31, 2010 08:27 PM
laurielalone
Feb 5, 2010 01:17 PM
jagnut1025
Apr 11, 2009 11:30 AM
