Sunvisor clips ?
Old Jul 5, 2012 | 06:02 AM
magredvet's Avatar
Default Sunvisor clips ?
Ok so when I got my jag, both of the sunvisor clips were broken, no problem thinks I, and $20 later I have two new ones installed. However after driving a total of 24, yup 24 miles, both of the new ones have broken off ! The new ones I bought came in Jaguar packaging, so I guess they are original items.
Is there some trick to installing them, or have I just been unlucky, and should go ahead and buy 2 more ?
I'm thinking maybe on old stock, the plastic has become brittle, and that's why they broke so quickly, anyone have comments, or a solution ?
Old Jul 5, 2012 | 09:35 AM
Roger95's Avatar
You're not unlucky - they just don't last long. Glue the broken part back into postion and fill the clip with epoxy. I've found this works as a cheap repair for these clips that continually break.
Old Jul 5, 2012 | 01:48 PM
Mike Beda's Avatar
I had the same problem with my '96 XJS. When I got the new clips I noticed that they are hollow inside, which looked pretty weak to me. So I filled the hollow insides of the new clips with epoxy putty (also known as Marine putty) before installing them and they haven't broken again.
-mB
Old Jul 5, 2012 | 02:14 PM
Vee's Avatar
Vee
I had the same problem with mine as well. I inserted washers into the hole and they have lasted for two years and still going.
For some reason I recall finding square washers that were almost a perfect fit at my local hardware store.
Seems like there are a lot solutions to this problem...funny how Jaguar found none of them.
Old Jul 5, 2012 | 02:15 PM
magredvet's Avatar
Thanks for the tip guy's, I'll try the epoxy route !
Old Jul 5, 2012 | 03:53 PM
GatorJoe's Avatar
I bought OEM replacements and noticed the very tight fit with bar and clip right away, before installing, so I opened them up a little bit with my fingers before screwing them in. The visor bar goes in and out like it should. 6 months so far and no problems.
Old Jul 5, 2012 | 08:20 PM
anjum's Avatar
I've had the same problem, bought another one fitted it and it broke again. Gorilla glue and open the front gap up a bit by using a file and positioning while the glue sets using suitable size rod.
Old Jul 6, 2012 | 05:47 AM
warrjon's Avatar
A common problem this.
I bent a piece of 1mm steel in a U shape that fit inside the clip, fixed it in the clip with rivets and then screwed it back in never broken again.
Old Jul 6, 2012 | 05:01 PM
EcbJag's Avatar
I bought new ones and just didn't tighten them that much. Just barely "snug". Then my sun visors were stuck so I just went blind rather than risking breaking another set. :-)
Old May 27, 2015 | 10:39 AM
Vee's Avatar
Vee
Dammit! My clip broke again. It did last awhile.
I'm sorry to resuscitate this old thread. Is everyone still going strong with the epoxy route?
Should I rough up the inside surface? Better to use the putty over the two-part liquid?
King Charles
Oct 16, 2015 01:25 AM
dmatthewman
Sep 30, 2015 10:10 AM
BlacXJRcat
Sep 25, 2015 06:43 PM
