Telescoping steering column 1978 XJ-S
Old Jul 4, 2019 | 04:45 PM
CZSteve's Avatar
Default Telescoping steering column 1978 XJ-S
I'm assuming there is supposed to be a way of locking the telescoping steering column on my '78 XJ-S?
The steering wheel moves freely fore and aft a few inches.
I'm assuming the large plastic black knurled hub behind the wheel and around the column is what's supposed to lock the wheel into position but does not seem to have any impact; it's difficult to rotate but I can with some force but does not accomplish anything.
1. Correct that telescoping column should able to be locked into a position?
2. Proper procedure?
Thanks,
Steve
Old Jul 4, 2019 | 07:59 PM
jag-reflex's Avatar
1. Yes
2. viewed from the driver's seat, turn the collar (the black hub thing) counterclockwise to loosen, adjust height, turn collar clockwise to tighten.
Old Jul 6, 2019 | 03:01 AM
leo newbiggin's Avatar
The "wheeler Dealers" tv programme weredoing up an xj6c and had the same problem. they stripped the column and found the locking collet had broken. get it on youtube
Old Aug 17, 2019 | 09:19 PM
fat_cat's Avatar
Had the same problem on my 77' but i just put some elbow grease into it to tighten it down
philip295
Jan 17, 2018 08:50 AM
carsnplanes
Dec 31, 2017 03:24 PM
sunchip
Jan 26, 2017 10:33 PM
Cherry_560sel
Aug 12, 2014 10:44 PM
Bollotti
May 11, 2012 06:19 AM
