Is there a source for the 4.0 facelift AC hoses
Old 05-12-2019, 05:25 PM
Time-Pilot's Avatar
Default Is there a source for the 4.0 facelift AC hoses
Title says it all, I have a badly leaking non-serviceable service valve on the high side. I checked the usual sources and nothing.
Old 05-12-2019, 06:08 PM
Jagboi64's Avatar
Received 3,072 Likes on 2,040 Posts
On my 1994 V12, the valves are standard GM style parts that screw on. I'd take a closer look! That being said, an AC shop should be able to make up new hoses.
Old 05-12-2019, 06:17 PM
Time-Pilot's Avatar
These are sadly 1st generation 134a ball valve style soldered right to the hard line. AC is probably the only way.
Old 05-12-2019, 09:43 PM
Jagboi64's Avatar
I thought they were hard attached at first on the V12 hoses too, but it turned out they were not. As I mentioned, standard GM style fittings with the ball inside instead of a shrader valve..
Old 05-12-2019, 11:00 PM
Time-Pilot's Avatar
Well, then I’ll have another look.
Old 05-12-2019, 11:09 PM
Jagboi64's Avatar
The high side insert. You're looking for the joint right under the quick connect groove.
I think it's AC Delco number 155438
Old 05-13-2019, 07:07 PM
Time-Pilot's Avatar
Spot on. I removed the low side fitting and the 5lbs of pressure in the system shot that ball valve across my garage into oblivion. I will have two new valve-core style fittings here tomorrow thanks to another post here with the O'riely part numbers. Then a quick vac down and recharge. I suppose I should have put my recovery machine on it but I really thought it was empty.
chXFS
05-30-2022 11:02 PM
CruizinKev
10-09-2017 09:12 AM
hoodun
10-30-2012 08:23 PM
priest2705
03-04-2011 09:47 AM
Quick Reply: Is there a source for the 4.0 facelift AC hoses
