Is there a way to empty the gas tank on a AJ16
Old Dec 27, 2015 | 01:11 PM
Spikepaga's Avatar
Default Is there a way to empty the gas tank on a AJ16
Hello guys;
I haven't been paying too much attention to my cars lately because they where just consuming all my time and not allowing me to spend time on any other interests. Oddly enough, ever since I decided to take a step back they have decided to be totally problem free....don't get me wrong, I still double park and wax regularly, but I have now decided to just let others take care of "most" of the maintenance and to stop cruising eBay for parts I really don't need.
Anyway, the one thing my XJS needs is a new fuel sender. Which seems like a very easy thing to change on a convertible. no it's not the module, I tried a new one and it's still going up and down like crazy.... I might give it a go and change it myself, but I think the tank should be empty. How can I drain it? Has anybody changed their sender in their convertible?
Thanks!
Old Mar 8, 2016 | 09:38 PM
lonejag's Avatar
Unsure if you are still needing to do this. Siphon the fuel from the tank.
Old Mar 9, 2016 | 07:13 AM
orangeblossom's Avatar
Originally Posted by Spikepaga
Hello guys;
Thanks!
Hi Spike
I've changed both the Sender and the Fuel Pump on my 1995 Celebration Convertible, where the Fuel Tank was located behind a Steel Baffle plate and while changing the sender is easy.
I found it a bit of a PIA to get to.
Old Mar 9, 2016 | 04:43 PM
Steve M's Avatar
Drive it 'till it stops?
Old Mar 10, 2016 | 12:23 PM
catterwaller's Avatar
Assuming it is like my 92. The sender access is from the trunk/boot behind the spare tire. It can be changed out without much trouble with 1/2 tank or less. I've done it a coupe times as I put it in upside down the first time. Pay attention to how the arm is bent as it comes out.
Old Mar 20, 2016 | 04:44 AM
Spikepaga's Avatar
Thanks for the replies. It was a 20 minute job, took the spare, and the carpeting out. Took the battery out two just to avoid a hazardous situation, thankfully the gas level was just bellow the opening when I removed the sender. Seems to have solved my problem
RobbyHughes
Mar 8, 2016 07:46 AM
Lemons Racer
Jan 25, 2016 04:33 PM
jamesackerman
Dec 29, 2015 06:18 AM
RobbyHughes
UK & Eire
Dec 21, 2015 07:52 AM
madshifter
Dec 21, 2015 06:04 AM
