Those hideous side guard stick on moldings are gone
Old Oct 5, 2023 | 06:13 PM
AZDoug's Avatar
Default Those hideous side guard stick on moldings are gone
Since the car had been resprayed, i had concerns that some paint may lift when the moldings were peeled off.
That didn't happen, but they left a bunch of foam covered adhesive on the paint.
Peeling the moldings off took about 5 minutes, doing it carefully, removing the foam back and adhesive from the car took about 5 hours, including clean and wax the areas.. My fingers and thumb are sore, but the car looks a whole lot better now.
To refresh your memory, here is before pic.
Doug
Old Oct 5, 2023 | 06:56 PM
dangoesfast's Avatar
For future reference, tar remover (detailing product) also does a great job of melting adhesive. I'm pretty sure most tar remover is just turps 😂
Old Oct 5, 2023 | 09:51 PM
AZDoug's Avatar
I was using commercial (Auto paint store) adhesive remover. WD-40, which is tar remover was not giving desired results.
I could have used the WD-40 and a credit card scraper like they show on how to remove adhesive vids, but only on something I didn't care about, like an ugly pedestrian car such as a Yugo, Trabant, or Fiat Multipla.
Doug
Old Oct 5, 2023 | 10:47 PM
Doug
Damn that must be some serious adhesive, tar remover has always got rid of sticky gunk in a few minutes when I've tried!
Old Oct 6, 2023 | 07:36 AM
bigcatrescue's Avatar
Yes those are hideous and you have earned a few points of esteem with the Jag gods for doing your part to remedy an obvious booger job from a previous misinformed owner I suspect. This is right up there with removing a hood leaper, chrome wheel arch covers, or non-OEM wheels (BBS excluded). BTW nothing beats Goo Gone for removing adhesive sticky stuff. Keep up the good taste!
Old Oct 6, 2023 | 01:31 PM
AZDoug's Avatar
The Goo Gone didn't work well, either. I already had some of that. Maybe it was the age of the adhesive.
BTW, I bought one of these a few months ago. Worth its weight in gold for cleaning wheels and doing low side jobs (like adhesive removal) on cars, esp once you get over 50 years old.
https://www.harborfreight.com/compac...eat-57317.html
Doug
Old Oct 6, 2023 | 04:09 PM
Jagsandmgs's Avatar
I like 3M Specialty Adhesive Remover. The first can lasted me 15 years so $40 is not unreasonable.
3M Specialty Adhesive Remover 38984, Transparent, Solvent Based, Easy Residue Removal, 1 quart https://a.co/d/iyJhE1t
Old Oct 6, 2023 | 07:36 PM
Mac Allan's Avatar
@AZDoug You won't miss the previous owner's inability to install the moldings in a straight line, it was quite wavy gravy.
Good work!
Old Oct 7, 2023 | 12:04 AM
Doug's Avatar
There is something to be grateful for. Back in the day a lot of those add-on side mouldings were riveted on. Removing them means filling a kajillion hundred holes and repainting!
Old Oct 7, 2023 | 10:03 AM
Mine are riveted.
As the BLACK is Real paint with Carbon Black, and not that water-based dark gray garbage they call black these days, I'm not messing with them.
Old Oct 7, 2023 | 09:48 PM
purrkittypurr's Avatar
... BTW, I bought one of these a few months ago. Worth its weight in gold for cleaning wheels and doing low side jobs (like adhesive removal) on cars, esp once you get over 50 years old.
Doug
That stool is called Grant's. Is this an invention from the mighty Grant from down under?
Old Oct 9, 2023 | 07:11 AM
sanchez's Avatar
My H&E had the riveted type moldings. I removed them for the respray but did not weld up the holes and have no plan to do so. I plan to replace them and purchase new inserts.
This was when I got the car and before the respray
Old Oct 9, 2023 | 10:04 AM
AZDoug's Avatar
At least yours were put on straight and didn't have weird end cuts at the fender wells.
Doug
Ezrider
Exterior
Jan 31, 2021 05:00 AM
pdwiggin
Aug 21, 2020 08:37 PM
Dogbreath!
Jul 4, 2016 09:48 AM
j.w.s
Detailing / Car care
Jun 8, 2015 01:34 PM
foxteca
Aug 28, 2013 01:14 PM
