Throttle Body Cleaning
Old Sep 26, 2012 | 04:11 PM
mannymux's Avatar
Default Throttle Body Cleaning
Anyone ever did this? I have a 95 XJS. Anything I should know about? What product to use? Thanks...
Old Sep 26, 2012 | 05:06 PM
M90power's Avatar
ive got a set of TB's for sale for anyone else whos interested in this as well.
Old Sep 26, 2012 | 06:24 PM
Greg Edge's Avatar
The usual M90 post. "Hey buy my stuff"
Anyway remove the throttle body and use carb cleaner and a toothbrush sized wire brush to get them clean. Doing it in place does not work.
Old Sep 26, 2012 | 09:06 PM
mannymux's Avatar
Is there any gaskets to change while removing the throttle body?
Old Sep 26, 2012 | 09:19 PM
Gus's Avatar
Gus
I am not sure a wire brush is what I would use I would first try a soft toothbrush after a good spray of Throttle Body cleaner. You can get the cleaner at any auto parts store. On a TB that is not crusted I use this process Link JagRepair.com - Jaguar Repair Information Resource I hope this helps.
Old Sep 26, 2012 | 11:40 PM
M90power's Avatar
followed by the usual greg post. "hey im inadequate and im taking it out on other motorists."
Old Sep 27, 2012 | 07:20 PM
Greg Edge's Avatar
I usually buy a bag of the brass ones at Harbor freight. A tooth brush works too. The key is to have it in your hand so you can clean it real good. You may or may not need a new gasket. Depends on if it tears when removing.
silkcat
Jan 18, 2025 04:29 AM
xjrjag
Oct 24, 2024 03:09 PM
Gus
Oct 15, 2019 12:29 PM
mrplow58
Sep 9, 2015 11:27 AM
