throttle position sensor
Old Sep 30, 2022 | 10:15 AM
miamijohn's Avatar
Default throttle position sensor
Need Advice Please,
On my 94 xjs 2+2 with 4.0, I am trying to set the TPS. It is the rectangular 6 wire plug and so far I know the following. The top 3 wires are white with blue stripe, green, and black with blue stripe. The bottom 3 wire are red, black with yellow stripe, and green with yellow stripe.
With the key on, I have 5.05 volts on the white with blue stripe and 5.05 volts on the red wire. What and how do I check further and set the tps properly?
Thanks, John
Old Oct 1, 2022 | 07:00 PM
92/93 XJS's Avatar
John, your quest is confusing "to reset my TPS". The TPS gets it signals from the the airmass meter, among other elements on the motor. It "sets" itself when plugged in and communicates info automatically. What issue did you have that prompted your question?
Dave in AZ
Old Oct 1, 2022 | 08:10 PM
miamijohn's Avatar
Hi Dave,
When initially attaching the TPS to the closed throttle body and with the key on, there will be the 5.05 volts from the ECU, but then the TPS should be positioned to a lesser voltage for the proper idle speed. On other jag inline 6 engines, it is aprox. 0.25 to 0.75 volts. I am trying to determine which wires I should use for that adjustment.
John
Old Oct 1, 2022 | 08:40 PM
miamijohn's Avatar
Dave,
I think I found the answer. Upon reviewing the full electric schematics, three of the 6 wires go to the transmission control module. So that leaves 3 wires to the ECU. As I previously noted, all the other inline 6's have just a 3 wire plug to the ECU. So that leaves 3 wires to the ECU, so knowing which wire is the 5.05 volts from the ECU, I will back probe the other 2 wires and see if that is the adjustment needed of the less than 1 volt for proper idle.
John
conceptoys
May 1, 2021 11:11 AM
adenshillito
Apr 10, 2021 07:21 AM
Buzzaw
Jun 18, 2018 05:26 PM
chrismc50
Jun 29, 2014 08:20 PM
zmann96
Apr 28, 2011 09:35 PM
