Transmission
Old Nov 2, 2016 | 05:03 PM
ray13's Avatar
Default Transmission
Does a 1990 XJ6 and a 1993 XJS use the same transmission?
Old Nov 2, 2016 | 05:25 PM
Daim's Avatar
1993 V12 or 6 cylinder? If 6 and the XJ6 (XJ40) has the ZF 4hp22, then yes.
Old Nov 3, 2016 | 07:16 PM
ray13's Avatar
Default Trans
Yes it's the 6 cly.
Old Nov 3, 2016 | 08:02 PM
motorcarman's Avatar
The 1990 XJ6 uses the ZF 4HP24 (electronic) gearbox. The XJS should have the same gearbox.
The 1988/89 XJ6 uses the ZF 4HP22 (manual throttle valve cable).
bob
