Transmission issues after a two month rest
Old Feb 18, 2015 | 10:33 PM
Stargazer XJS's Avatar
Default Transmission issues after a two month rest
I've just taken my XJS home after a couple months at the shop, and noticed on the way home that the car doesn't shift like it used to. It'll hold first until about 40 mph and 4,000 rpm at which point it will shift rather abruptly (though smoothly) into second, and hold it with no complaints.
I got curious and accelerated onto a highway. Under a heavy foot the shifts were quick and smooth, though still noticeable, and I was able to get all the way into third.
The fluid is clean and full - bright red with no unusual burnt smells or foreign matter. It is rather cold at -7f and getting down to -12f or even lower tonight.
I guess the root question is - where should I look first? Searches have uncovered some pretty apocalyptic scenarios, and I'd like to think that I didn't just jump out of the frying pan and into the fire.
Old Feb 18, 2015 | 10:42 PM
Doug's Avatar
Don't get too worried at this point.
Might be as simple as a modulator failure. But first make sure that the vacuum hose to the modulator didn't break or fall off.
Old Feb 19, 2015 | 01:36 AM
Brake buster's Avatar
as above
also check the electrical kick down switch wire on the opposite side to the modulator ,
but its more likely that it has come off in the engine bay , presuming its a V12 ?
like Doug say , don't panic just yet , they usually get very noisy and troublesome before falling over
BB
Old Feb 19, 2015 | 12:37 PM
Thanks for the input
If I were to try to rule out the kickdown as being part of the problem, what would disconnecting the wires to the kickdown switch under the hood do for me? I have yet to take a closer look at, but tomorrow is looking to get up to near freezing, so I figure that would be a good time to go crawling under the car.
I'll have a closer look at that modulator too. I've got a spare, but it still should be solid.
Edit Loose vacuum line to the modulator. Had me worried for a bit though
Old Feb 21, 2015 | 09:19 PM
Dleit53's Avatar
Disconnecting the kick down switch would eliminate it's affect on the transmission. On my 78, the kickdown switch is on the throttle cable, just before the bell crank. The cable has to slide back and forth, about 1/4" against a spring to activate the kickdown. Mine was stuck in the no kickdown position, but if yours is stuck in the kickdown position, it will give the symptoms you are experiencing.
99xk8guy
Sep 29, 2025 10:51 PM
JarodL
Mar 7, 2024 01:39 AM
nd143
Sep 3, 2015 04:42 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
d a
Sep 3, 2015 02:34 AM
