Transmission Leak
Old Jul 29, 2012 | 08:34 AM
RayJak's Avatar
Default Transmission Leak
All,
I changed the transmission fluid and filter last year before I deployed and then the car sat for eight months until I got home. It started right up last week! I took it for a long drive (100 miles) after a few warm up trips. It was a hot day (110+ heat index here in Philly). The car seemed fine until I noticed a burning smell and could see smoke coming up underneath the car. It had transmission oil smell to it.
Anyway, I looked under the car and fluid is dripping onto the exhaust system. Does the car have an overflow port or valve? Maybe I put too much fluid in it an it is dumping the excess? Any thoughts before I jack her up...
Thanks,
Ray
Old Jul 29, 2012 | 09:38 AM
Doug's Avatar
I'm not aware of any auto trans that *doesn't* have a vent port of some kind...usually up high somewhere.
Broadly speaking I think you'd have to grossly over-fill the trans, or have a serious fluid overheating problem, for fluid to be ejected from the vent....but perhaps some transmission designs are more prone to such a thing than others <shrug>
Why not warm the car up and simply check the fluid level on the dipstick? That would answer the question of over-filling.
Old Jul 29, 2012 | 11:07 AM
Spikepaga's Avatar
Originally Posted by RayJak
All,
Thanks,
Ray
Hello Ray;
You might want to look at a couple of places for a leak; the transmission cooler lines and the rear transmission seal right above the transmission mount in the middle of the car. Both are common leak spots in the 95/96 models.
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
1LowCat
Feb 23, 2016 07:19 AM
