Transmission quirk
Old Jun 9, 2022 | 01:57 PM
twojags1992's Avatar
Default Transmission quirk
I recently purchased a ‘95 XJS V12 that has an odd transmission quirk: gears won’t shift between second and third until the engine is warmed up or you shut off and then restart the engine. The seller thinks it’s something electronic in the transmission.
Any thoughts?
Old Jun 9, 2022 | 05:13 PM
ptjs1's Avatar
twojags1992,
Is it just not changing out of 2nd when it starts off from rest in 2nd.? What happens if you make the car start off in 1st gear? Does it then change up into 2nd and then get stuck? Or will it then go from 1st to 2nd to 3rd then 4th?
Paul
Old Sep 22, 2025 | 06:53 PM
Tyee's Avatar
Any thoughts?
I'm not sure if this applies to the 4L80E transmissions Jaguar used but the early versions of this transmission used in GM trucks had a similar issue. The seal rings feeding the direct clutch (3rd gear) were a solid teflon? ring and they would shrink over time and they wouldn't shift 2-3 until they warmed up. The later units used a different material that eliminated the issue.
Old Sep 22, 2025 | 11:51 PM
Jagboi64's Avatar
As far as I know, the internals of the 4L80e were identical to the GM units with the exception of the wiring for the solenoids and external connector. The Jaguar version starts in second as the default unless in sport mode, GM starts in first.
Thus if you use a GM internal harness for the solenoid wiring it will be backwards to the way the Jaguar version operates.
Old Sep 23, 2025 | 11:20 AM
Tyee's Avatar
Good to know. 1'm a semi retired transmission tech and have rebuilt a few Jag M12 and TH400 units but never had the opportunity to do a Jag 4L80E.
sd63141
Jun 28, 2021 09:06 PM
Johnny Mayday
Dec 6, 2019 05:16 PM
98jags
Mar 4, 2013 09:25 AM
ghheath
May 16, 2010 04:35 PM
