transmission swap on a 96 6cyl 4.0.l
Old Jan 29, 2011 | 09:57 PM
rama1200's Avatar
Default transmission swap on a 96 6cyl 4.0.l
I think my current transmission is the ZF4HP24E (correct?)... it has about 170k miles and it stopped shifting about a year ago... I was wondering if the GM 4L80E would be a straight bolt on swap?
which one is more reliable?
would I be better off rebuilding my current one or buying a rebuilt 4L80-E?
what other things to consider?
Old Jan 29, 2011 | 11:01 PM
Doug's Avatar
Get the ZF rebuilt. They are good transmissions.
I'm not even sure the 4L80E would bolt up. It was used behind the supercharged 4.0 but I *think* those blocks had a different bolt pattern or an adpater plate was used.
Next is the electronic compatability between the 4L80E and your car's electrical architecture. Could be a big problem.
Lastly, even if you could make it work, the 4L80E is heavier and sucks off more power than the ZF.
aholbro1
Dec 29, 2024 06:46 PM
Jagged-X
Sep 24, 2015 05:08 PM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
mrplow58
Sep 15, 2015 09:58 PM
jerry_hoback
XJ40 ( XJ81 )
Sep 13, 2015 07:48 PM
