Upgraded radio now heat not blowing
Old Feb 20, 2016 | 06:17 PM
Qgregg's Avatar
Default Upgraded radio now heat not blowing
Hey guys 1988 jaguar xjs as you all know theres not much room for a new radio much deeper than the original.....well i put one in and now the blower is not engaging.....before i take on the task of removing the radio. Do you guys have any clue for what i should look for ?
Old Feb 20, 2016 | 07:44 PM
Doug's Avatar
Have you checked the fuses?
If the fuses are OK I'd pull the radio and look for any wires that may have been disturbed
Old Feb 20, 2016 | 08:08 PM
Qgregg's Avatar
Thanks doug will do, went through all the inside fuses they all look good. Will pull radio tomorrow. When i turn dial to low, med, auto or high (NOTHING) just when things were going good....... 😄
Old Feb 20, 2016 | 10:45 PM
baxtor's Avatar
Maybe you have dislodged an electrical connection or earth. You can get a pretty good look at what's going on under there by removing the forward console extensions, it's only two screws each side.
Old Feb 21, 2016 | 09:50 AM
Qgregg's Avatar
Originally Posted by baxtor
Maybe you have dislodged an electrical connection or earth. You can get a pretty good look at what's going on under there byw removing the forward console extensions, it's only two screws each side.
Well checked all fuses, pulled stereo out checked any connections i could get to. when i turn dial to low, med, auto or defrost you can hear a click or like something opens but no blowing.......of air.....
Old Feb 21, 2016 | 11:44 AM
Qgregg's Avatar
Just remembered i also pulled instrument cluster and changed bulbs is there anything behind the cluster that could be causing the blower not working ???
Old Feb 21, 2016 | 11:59 AM
Doug's Avatar
There are four fuse for the system; one is an in-line fuse....behind the RH console extension panel as I recall. Did you find and check all four fuses?
Old Feb 21, 2016 | 12:14 PM
Qgregg's Avatar
Checked any and all under steering colum, checked any and all under glove box. Not sure if this is the correct inline fuse or not but found on passenger side about where ones left knee would be. Think it was a brown wire.
Old Feb 21, 2016 | 12:16 PM
Qgregg's Avatar
Default Reply
Not sure why my reply did that
Old Feb 21, 2016 | 12:18 PM
Doug's Avatar
QUOTE]
That sounds like the one, yes
Old Feb 21, 2016 | 12:45 PM
Qgregg's Avatar
The inline fuse looks to be ok, did you see where i pulled instrument cluster around same time as stereo, could that be a cause? Everything behind stereo looks in tact.
Old Feb 21, 2016 | 01:06 PM
Doug's Avatar
OK, here's an idea.....
On one of the inlet pipes to the heater core there's a temp sensor with two wires. Are both wires attached? If not, the blowers cannot operate.
One of them might've become dislodged during the instrument cluster adventure. They sensor is in the same neighborhood, roughly, as the cluster.....
Old Feb 21, 2016 | 01:09 PM
Doug's Avatar
Just so you have a rough idea of what to look for the switch is #3 in this pic.
Air Conditioning Components - Parts For XJS from (V)139052 to (V)179736 | Jaguar Heritage Parts UK
It's mounted on a little tab on the pipe going into the heater core
Old Feb 21, 2016 | 01:42 PM
Qgregg's Avatar
Well i was hoping for the best but , the two wire are connected. the instrument panel is out.......everythings pulled out no air movement and ive got a huge mess.....any other ideas...thanks
Old Feb 21, 2016 | 02:02 PM
Qgregg's Avatar
[QUOTE=Qgregg;1407637]Well i was hoping for the best but , the two wire are connected. the instrument panel is out.......everythings pulled out no air movement and ive got a huge mess.....any other ideas...thanks[/QUOTE
Just thinking of anything else i could add i remember after i had installed stereo i cut the heat on and it seemed to struggle a little, after that seems as if i worked once or twice afterward. Also hear lately been having to pull battery cable everytime time im not driving because of battery drain, but that never interfered with blower not working after battery cable hooked back up to drive.
Old Feb 21, 2016 | 03:32 PM
baxtor's Avatar
[QUOTE=Qgregg;1407651]
For what it's worth l would check the unit is powering up. Ignition on, DMM positive probe to pin #1 (very top) neg. Probe to good ground, be very careful around pin #1.
Old Feb 21, 2016 | 03:49 PM
Qgregg's Avatar
[QUOTE=baxtor;1407703]
ill have to get my hands on a multi meter this week if possible and check pin one, an i correct that the test pins are on the passenger side up around where the inline fuse is except higher up small white rectangle with lots of tiny pins
Old Feb 21, 2016 | 05:07 PM
Qgregg's Avatar
[QUOTE=Qgregg;1407720]
Will i not have to remove glove box for this ? Because if i am looking at this correctly the strip of pins go up pretty high and i guess pin one is at the top?
Old Feb 21, 2016 | 05:36 PM
Doug's Avatar
Stretching a bit for a cause and cure, but.....
It's somewhat common for the blower circuit to malfunction and stay hot even after the key is turned 'off' causing a heavy battery drain. Of course, in this most typical of failure modes, you'd hear the blower motor/motors continue to hum. This is due to degradation of the diodes/relay/circuit board in one or both blowers.
http://www.jag-lovers.net/xj-s/book/acblower.htm
Old Feb 21, 2016 | 06:41 PM
Qgregg's Avatar
[QUOTE=Doug;1407766]
Air conditioning blower control
Wow what a job.....i did pull the glove box and tested pin one to ground and have power. This week ill run through all the test. And write down the results....Bad news for a split second pins 44 and 45 touched via probe end i can only pray no damage was done
