V12 Engine block identification
Old Mar 3, 2014 | 06:31 AM
xjr5006's Avatar
Blocks can be converted from rope to lip, rear of block needs to be welded up / have an insert made and welded in + insert for the rear cap + machining and line boring. Not cost effective on a road block.
Race cranks have a different rear seal to a road crank. Much easier conversion on this one. but still not where you want to be by choice.
So you really need to stick to a matching crank and block unless something special has dropped in your lap.
Old Mar 3, 2014 | 10:50 AM
ronbros's Avatar
yes, seems it could be done, BUT a lot of work, welding and machining, probably cheaper and more accurate, to procure a lip seal block and crank.
as said by 5006
Doug
Feb 27, 2019 01:31 AM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
cissdm
May 3, 2016 06:02 AM
Broken_Spanners
Sep 6, 2015 11:34 AM
d a
Sep 3, 2015 02:34 AM
