V12 only running on 6
Old Aug 14, 2021 | 01:08 AM
brinny's Avatar
Default V12 only running on 6
Morning all, my v12 appears to only be running on the b bank. If I’ve put the distributor back in a tooth out is that likely to be the problem? Anything else I should look for? Thanks again for your help
Old Aug 14, 2021 | 01:37 AM
Greg in France's Avatar
Is it a Marelli car, Brinny? If it is you have the classic Marelli failure.; = dizzy arcing or amp failed, or broken wires to same.
Old Aug 14, 2021 | 01:58 AM
orangeblossom's Avatar
Hi Brinny
If I remember correctly, your V12 is a Marelli 1989
So as 'Greg' says you've got the Classic Symptoms of a Marelli failure
Take the Dizzy Cap off and look for signs of Arcing
Old Aug 14, 2021 | 02:22 AM
brinny's Avatar
Ok . I hope it’s not that I’ve just put a new genuine marelli cap on. Did the mod to prevent arcing which makes me think I’ve put the dizzy in a cog out. Does it ever end lol
Old Aug 14, 2021 | 02:31 AM
Hi Brinny
It could equally be the Rotor under the 'Dizzy Cap'
And in answer to your question, No it never ends 'There will be pain!'
Old Aug 14, 2021 | 02:38 AM
baxtor's Avatar
Are all the obvious no brainers accounted for, ie. both coils and amplifiers connected. Might also need to check cap coil lead to rotor contact brush.
A cog out on a marelli could do it though with spark being generated between plug leads and nowhere to go but that would effect all 12.
Old Aug 17, 2021 | 06:38 PM
HRH-UK's Avatar
Check the Manifold Pressure Sensor. I assume it runs very rough and you can stop it from stalling if you throw it in neutral when you come to a stop and feather the throttle?
olivermarks
Feb 17, 2018 07:59 PM
Andreas Schmieg
Jan 27, 2017 07:15 PM
FastCat85
Nov 25, 2015 06:38 PM
velder
Jul 6, 2011 01:28 PM
