V12 Timing Chain rattle
Old Aug 13, 2017 | 11:50 PM
Sarc's Avatar
Default V12 Timing Chain rattle
We were slightly off mission today and got distracted by a "cheap" XJS that was advertised locally.
The owner said it ran but made a "ticking" noise....
Neither myself nor smgdata had heard this particular sound from a V12 before......
Unfortunately on closer inspection it appeared to have a broken timing chain tensioner. We could wiggle the timing chain about an inch with a screw driver through the oil filler cap.
Just wanted to get feedback if our diagnosis was correct ?
Old Aug 14, 2017 | 12:39 AM
Daim's Avatar
Sounds like a loose chain. That chattering sound is a typical loose chain sound.
I think best way to determine a broken tensioner would be to pull the front rubber bungs and stuff a little cheap endoscope camera in there.
Old Aug 14, 2017 | 03:52 AM
Spot on.
The quietening on acceleration, and the clatter on overrun are the key.
Have fun.
Old Aug 14, 2017 | 12:37 PM
Andreas Schmieg's Avatar
In a 5.3l V12 engine, will the valves hit the pistons when the timing chain fails?
Rumor has it that this is how XK8 (AJ26) engines tend to die.
Old Aug 14, 2017 | 11:03 PM
Sarc's Avatar
Ok, thank you team.
Pity..... The rest or the car was actually pretty good, but just too many things going on right now.
I know the AJ26 is an interference engine (valves collide with cylinders if timing is off)..... Good question about the V12........ anyone?
Old Aug 15, 2017 | 02:23 AM
HE, I seriously doubt it.
The flat head PreHE, not sure, it would be tight.
Old Aug 15, 2017 | 06:25 AM
Daim's Avatar
Rumor? No... Real life. All AJ26 and AJ27 until August 2001 will die if not treated Done it about 19 times since last year!
Old Aug 15, 2017 | 06:32 AM
Daim's Avatar
That is weird, as technically then a new chain fitted wouldn't be that expensive compared to if the valves smash into the pistons. But I have read about valve damage on some V12s. Just not sure if HE or flat head...
Anyhow... I'll then drive like an old Volvo red block owner. Until the chain/belt snaps... And then simply fit a new one
Old Aug 15, 2017 | 07:29 AM
The valve noise you are remembering is when the HE drops a valve seat from massive overheating. Generally mashes itself into a pulp, then the head of the valve parts company with the stem, and the piston becomes a very LO comp version.
The preHE did not have that problem that I have ever come across.
Drive it like ya stole it, the only way to keep a V12 running proper.
Old Aug 15, 2017 | 07:45 AM
Daim's Avatar
AH yeah that was it! Valve dropping.. Cheers Grant! Once I get my V12 running again, I'm out for a fun day hooning. I have been told the V12 likes to be held up in the upper third of the rev counter
The last drive I did in mine before taking it apart was to go to a tunnel and just toe it! 1st gear and wellies! Oooooh did that sound nice! There aren't many tunnels here, so I went to my nearest one late at night... Mmmmhm delicious!
