V12 TPS adjustment tidbit
Old Sep 29, 2021 | 07:35 AM
Doug's Avatar
Default V12 TPS adjustment tidbit
I'm tinkering with TPSs again. More on that in a different post, later.
As most of us probably know, adjusting the TPS is tricky because it always wants to move a tiny bit as you tighten the screws. Frustrating as hell.
I wondered if hold-down nuts might work better? I cut the heads off the screws, thus turning them into little studs. I then found some "Keps" (sometimes called "K-Lock") nuts. These have an integrated toothed washer installed such that the washer remains stationary as the nut is being turned
It works ! The teeth of the washer grip the TPS . As you tighten the nuts the TPS stays exactly where you set it!
Old Sep 29, 2021 | 07:40 AM
BRILLIANT.
Old Sep 29, 2021 | 02:31 PM
JayJagJay's Avatar
What SIZE is them there NUTTS?
Old Sep 29, 2021 | 03:06 PM
Xjeffs's Avatar
I ran into the same thing with the red TPS. I used long Allen head bolts with star washers and fixed the movement also.
Old Sep 29, 2021 | 06:03 PM
Doug's Avatar
Can't remember the size, sorry.
5mm-1.0 thread pitch?
Sorry
Old Sep 30, 2021 | 12:37 PM
JayJagJay's Avatar
Sorry
Okey dokey... Thanks Doug
Old Oct 1, 2021 | 01:19 AM
leo_denmark's Avatar
Sorry
The European engineer feels a need to comment on this: M5 standard pitch is 0.8, so that's much more likely.
cdnp62000
E type ( XK-E )
Feb 24, 2022 05:45 AM
scottpeterd
Sep 24, 2020 05:44 AM
MussieRon
Jul 12, 2020 11:58 AM
J_C_R
Mar 12, 2020 02:38 PM
wradford
Oct 31, 2010 05:29 PM
