V12 transmission cooler lines?
Old Apr 16, 2024 | 08:36 AM
outsidecenter's Avatar
Default V12 transmission cooler lines?
There are these two hard metal lines that connect to the radiator. One hits the top beneath the upper radiator hose and one connects down low. I cannot seem to get it off because none of my box ends fit and neither does my adjustable crescent wrench. Any advice on how to get the lines off? I'm replacing the water pump and radiator.
Old Apr 16, 2024 | 09:17 AM
nickr76's Avatar
I dont recall what size i used, but i had no trouble getting these off when I swapped auto to manual.
is it a clearance issue?
Old Apr 16, 2024 | 09:59 AM
Yeah it is a clearance issue and because of the lack of clearance I can't get a positive engagement to be certain what size it is.
Old Apr 16, 2024 | 08:15 PM
RGK20m3's Avatar
Having just done this today, nut is 19mm and hex on adapter is 14mm. A 3/4” is tight but will work. 9/16” fits adapter just fine.
Old Apr 16, 2024 | 08:25 PM
I got it off with the smallest pipe wrench but I'll try your measurements to put it back on. Problem is the aluminum bolt on radiator I bought online isn't the same as factory.
The transmission line fittings on the radiator is off-set because they are mounted on a tapered side of the radiator rather than straight ahead like factory. I will try to bend the line ever so slightly forward and see if I can reach it.
The top should be ok but the bottom line is worrying me.
Photo is me looking down at the bottom tranny line mounting point and you can see the end of the line itself and the gap between them.
Old Apr 17, 2024 | 06:06 AM
RGK20m3's Avatar
You could always replace the rubber section of that lower line with a longer section which might allow a different route. A lot easier with the radiator out.
Old Apr 17, 2024 | 07:21 AM
nickr76's Avatar
I have a perfect set of these if anyone needs them.
Old Apr 17, 2024 | 08:16 AM
I obviously do but I don't have time for shipping. Where can I find them at the store?
Old Apr 17, 2024 | 11:21 AM
nickr76's Avatar
pay for shipping(from Canada) and you can have them for free.
razorboy
Jun 17, 2023 08:24 PM
owas
Aug 8, 2019 03:47 PM
al_roethlisberger
Jun 13, 2018 12:45 PM
soceraz
Mar 14, 2018 09:23 AM
atilamejias
21
Mar 1, 2008 07:11 PM
