V12 valve guide
Old May 8, 2013 | 03:01 PM
Per's Avatar
Per
Default V12 valve guide
I need to replace an exhaust valve guide. The guides available are oversize, two steps. The workshop manual doesnt mention this so which one to choose? Further the wsm says to heat the head in boiling water before drifting out the old and the new one in. Unfortunately I do not have a big enough container. So any bright ideas? I rather doubt that wrapping in black plastic and leaving in the sun will do the trick .......
Old May 9, 2013 | 06:40 PM
ronbros's Avatar
we used an old pizza oven, it was wide enough for long aluminum heads, just be careful not to much heat, around 300-400*F.
while your at it, measure the surface flatness, if its not bad you can straighten it out, with the heat, then
when all guides and straightness is done a nice light resurface cut.
something to remember is if the head is warped,the cam bearing bores will be out of alignment also, could lead to future problems.
Old May 20, 2013 | 09:31 PM
calvindoesntknow's Avatar
I did my friends bmw head by boling water in a five gallon bucket and did one side at a time
1100me
Jul 24, 2023 06:10 PM
JWheeler
Nov 22, 2019 08:28 AM
rfarmery
Sep 21, 2015 06:14 PM
ratgawd
Sep 16, 2015 04:15 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
