Vacuum fuel temp sensor
Old Jan 4, 2024 | 10:16 AM
rgp's Avatar
rgp
Default Vacuum fuel temp sensor
I have a vacuum sensor to plumb in, does it matter where the vac supply and the fpr pipes go. 1 way is slightly easier to blow through than the other.
Old Jan 4, 2024 | 03:30 PM
rgp's Avatar
rgp
I can answer this myself now. So don't reply.
Old Jan 6, 2024 | 09:21 AM
RGK20m3's Avatar
Might want to share to help others. It does matter, as there is a vent to reduce vacuum on the switched side when in the off position.
Old Jan 12, 2024 | 06:06 PM
orangeblossom's Avatar
Hi rgp
You don't even need it!
Just join those 2 pipes together and take it out of the mix
You can just leave it in there, or remove it altogether, as there is nothing behind it, its Blanked OFF
Old Jan 18, 2024 | 03:46 PM
rgp's Avatar
rgp
Originally Posted by orangeblossom
Hi rgp
Oops, went in twice.
Old Jan 18, 2024 | 03:49 PM
rgp's Avatar
rgp
Hi rgp
Hi OB, it's a heat sensor so it actually just get the heat off the rail, doesn't need to go into the fuel. 😊😊
Old Jan 18, 2024 | 06:27 PM
Hi rgp
It's a Wax Thermostat that Controls the Vacuum that under Certain Conditions (if the Fuel in the Rail Should get Very Hot) it can enrich the Mixture for Easier Starting
In which case the Wax Stat Closes which then cuts down the Vacuum to enrich the Fuel Supply and then opens again when the Fuel is Flowing Normally, so indirectly it does affect the Mixture
While that may be the 'Theory' in Practice it's not needed. except maybe under Extreme Climatic Conditions, as even with it taken out of the Circuit by joining those Tubes Together or just replacing both of them with a Single Vacuum Tube, almost 100% of the time your Car should Start and Run as Normal
This Wax Stat can also be more trouble than its worth as if the Engine should get very Hot and the Wax in the Wax Stat Melts as it did on mine, unless you were aware of this your Fuel Consumption could go up, for what appears to be no logical reason and even cause back firing as mine did
Once I'd taken the Wax Stat out of the Circuit by using a Single Tube, everything then returned to Normal and I've never had that kind of problem since, with Thanks to 'Grant' 'The Wizard of Oz' who found out what was wrong and showed me how to Fix it
Sweet Smell Followed By A Massive Bang
rhvh2000
E type ( XK-E )
Dec 18, 2023 12:34 PM
MudDog
Sep 1, 2022 07:59 AM
Robbo D
Aug 21, 2021 11:08 PM
neinz
Jul 29, 2017 03:46 PM
Andreas Schmieg
Nov 28, 2016 02:34 AM
