vacuum lines & leaks
Old Aug 26, 2013 | 09:01 PM
big john's Avatar
Default vacuum lines & leaks
84-5.3 he, I believe I have a vacuum leak as under heavy throttle the blend door goes to the default defrost position. At the rear of the right intake I see 19 inches of vacuum at idle, Are there any Most Likely places to start testing?
Also, ARE all the extra vacuum devices- dump valve, and delay valve are needed. Can the vacuum advance be connected directly to the vacuum port?
Has any one changed the heater/ac control system to one the uses cables to control the blend & function doors?
clubairth1
30
Sep 3, 2025 04:38 PM
silkcat
Jan 18, 2025 04:29 AM
Bcrary3
Feb 21, 2023 04:29 AM
explorer364
Sep 11, 2015 05:44 PM
OkieTim
Sep 8, 2015 04:48 PM
