What If...
Old May 20, 2014 | 04:09 PM
  #61
xjsv12's Avatar
Yellow lable
Old May 20, 2014 | 04:11 PM
  #62
xjsv12's Avatar
view from the top
Old May 21, 2014 | 01:13 PM
  #63
Flint Ironstag's Avatar
Love that overhead view.
Old May 21, 2014 | 01:17 PM
  #64
JagZilla's Avatar
I agree. That does a great job of showing the curve of the wider fender panels.
Old May 21, 2014 | 04:04 PM
  #65
xjsv12's Avatar
what do you think about gearbox?
4L80E 6-Pinion Planetary Sets (1991-96 2.97 1st/1.57 2nd Gear Ratios) - TCI® Auto
They have and for TH400
TH400 6-Pinion Planetary Set (2.97 1st/1.57 2nd) - TCI® Auto
Is TCI good ?
Old May 21, 2014 | 04:36 PM
  #66
xjsv12's Avatar
Originally Posted by calvindoesntknow
How much different is the db7 suspension than the xjs suspension?
Upper and lower wishbone, hub, stub axle carrier , steering rack ball joint and damper lower mounting bracket . All other is the same xjs.
Old May 22, 2014 | 08:06 AM
  #67
JagZilla's Avatar
Originally Posted by xjsv12
TCI has a good reputation here in the USA, and as far as I know, they build tough automatic transmissions that are widely used in Drag Racing.
Either of the options you listed will be a huge improvement over the stock Turbo 400 that you have now. However, if you are going to spend that much money, why not change over to a 5 or 6-speed manual transmission?
Old May 22, 2014 | 08:32 AM
  #68
JagZilla's Avatar
xjsv12,
Do you have better photos of your grill? From what I can see in your pix, it looks very similar to what I am planning for JagZilla's grill.
Old May 22, 2014 | 11:23 AM
  #69
JagZilla's Avatar
Originally Posted by 1800doogie
TWR ran a 11 1/2 rear wheel. They cut 2 inches out on the inner wheel well, then welded it back up. Finished result looked factory.
1800doogie,
I'm curious about how they managed that without also modifying/relocating the rear subframe rails, which are pretty much flush with the inner wheel well, if I remember correctly. Is there a reference to it in Allan Scott's book?
***EDIT***
Never mind. I found it on pages 46 & 47.
Old May 22, 2014 | 01:58 PM
  #70
Steve M's Avatar
Going back to the original question of 'What if', how come there was never a factory built Ute?
Old May 23, 2014 | 08:38 AM
  #71
JagZilla's Avatar
Probably because Jaguar knew something like that would never sell enough units to pay for the tooling. It has no character, no pizazz.
On the other hand, something like this would be a huge seller here in the US
'cuz we be pimp'n. lol
Old May 23, 2014 | 09:56 AM
  #72
Steve M's Avatar
Perhaps, but yours is just silly! It's a Jaaaaag, it should be somewhat understated.
Old May 23, 2014 | 10:31 AM
  #73
JagZilla's Avatar
That?
That's not silly.
This is silly:
In retrospect, do you see how "not silly" the other Jag was? LOL
Old May 23, 2014 | 02:21 PM
  #74
Steve M's Avatar
Nah, just silly; the next one is very silly!
Old May 23, 2014 | 02:38 PM
  #75
JagZilla's Avatar
All joking aside, The photo you posted may not be my pick as the ideal model to use as a ute, but, the craftsmanship was very evident. I've seen one or two photos of well executed XJS ute conversions over the years, and, because of the flying buttresses, they actually present as a half decent looking ute.
Old May 23, 2014 | 02:56 PM
  #76
JagZilla's Avatar
Speaking of silly...
Old May 23, 2014 | 04:11 PM
  #77
Steve M's Avatar
Extremely silly but it looks like a huge amount of work has gone in to it. I like the rear treatment where the back window is removed completely and the cross over spoiler fitted, neat job.
Old May 27, 2014 | 03:03 PM
  #78
xjsv12's Avatar
Originally Posted by JagZilla
xjsv12,
Sorry for delay
Attached Thumbnails What If...-2014-05-22-20.44.15-2.jpg   What If...-2014-05-22-20.44.46.jpg   What If...-2014-05-22-20.45.02.jpg
Old May 27, 2014 | 07:43 PM
  #79
JagZilla's Avatar
Thanks xjsv12. That is very similar to what I have planned for my grill, except that I will likely paint the mesh black, to contrast the chrome V12 emblem and grill frame.
Old Jun 24, 2014 | 12:47 PM
  #80
JagZilla's Avatar
I dunno Steve M. This profile of the so called Tiger Car is pretty hideous. It appears that they took the stock rear side windows, and rotated them in such a way that their current bottom edge is what used to be the front edge, and they have slanted the rear point of that window downward in such a way that it completely destroys any possibility of a flowing, cohesive design, giving the car a very ungraceful and clunky appearance.
I do, however, like the front and rear bumperette treatment, and have just about settled on doing something similar, instead of my original plan to weld two sets of chrome bumper blades together in order to create a slim, all-metal, horizontal bumper.
Or, in keeping with my semi-competition theme for the car, I may do something like the jacking points Shelby put at the front and rear of the 427 SC Cobras. Those should be fairly cheap, and easy to source from any Cobra kit car manufacturer.
