What is this piece?
Old Sep 23, 2014 | 03:04 PM
SeanPeterLynch's Avatar
Default What is this piece?
I dont have pictures this moment, but going to describe it.
1989 J XJS 5.3 V12.
On the drivers side of the engine, towads the top of the engine (closest to driver), there is a rubber wide tube that fits onto a maybe 1inch diameter metal fitted bevel.
What is this? Pics will come but figure many of you know these better than the back of your hand.
Old Sep 23, 2014 | 03:53 PM
sidescrollin's Avatar
bevel? Not sure what you are talking about by the description .First thing that comes to mind with 1 inch tube is the drain for cowl, but that appears on both sizes of the car.
Other two things I can think of is the boot/cover for the PCV filter and the air balance tubes in the back. The air balance tubes are on both sides in the center though.
Old Sep 23, 2014 | 04:11 PM
JTsmks's Avatar
Sounds like the cowl drain tube.
Old Sep 23, 2014 | 04:47 PM
Yep must be cowl drain. Thanks guys. Not the air balance tubes.
bdboyle
Sep 16, 2019 05:58 PM
King Charles
Oct 16, 2015 01:25 AM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
