What is this relay?
Old Jan 23, 2012 | 08:59 PM
Mish_Mish's Avatar
Default What is this relay?
I have this green relay in the right rear fender area and not sure what it does. I believe it was mounted somewhere close to tail light, but not sure what it does and where this bracket mounts.
Thanks!
Old Jan 23, 2012 | 10:29 PM
Doug's Avatar
Looks like an antenna relay.
With the wire colors and/or terminal numbers we can verify
Old Jan 24, 2012 | 01:46 AM
Greg in France's Avatar
Yes, definitely the aerial relay.
Greg
Old Jan 24, 2012 | 07:24 AM
Thanks!
I forgot to say in my earlier post. The bracket mounts across the gap between the outer wing and the exhaust tunnel top. The right angled end of the bracket is fixed by the same bolt that fixes the side-bumper to the rear quarter panel. The bracket is usually fixed onto the first bolt nearest the front, or the next one, and the relay mounted under the bracket for protection. The other end bolts to the tunnel top, and one of the relay wires must be earthed for it to work. The relay has a timer in it which will hold the aerial up for a few seconds after the radio is switched off.
Greg
Old Jan 24, 2012 | 07:27 AM
Mish_Mish's Avatar
Greg
Thank you!!! I suspected that it was one of the less important relays. I am planing to mount it next to the other two relays on the outside of rear wheel well, close ECU box. I hate all these over-engineered brackets and mounts all over the place.
hoodun
Nov 20, 2022 02:35 PM
jagent
Jun 5, 2022 02:18 PM
asleach2889
Oct 1, 2015 01:53 AM
Mark SF
Sep 28, 2015 01:51 PM
