What's The Best Way Ff Testing Spark Plugs Without An OBD Reader?
Old Sep 5, 2018 | 04:18 PM
orangeblossom's Avatar
Default What's The Best Way Ff Testing Spark Plugs Without An OBD Reader?
What's the Best Way of Testing the Spark Plugs without an OBD Reader?
XJS Facelift with 4.0L AJ16 Engine
Old Sep 5, 2018 | 06:35 PM
Jagboi64's Avatar
Huh? You don't test spark plugs, replace them. As they are used, the edges of the electrode wear and round off, that makes it harder for the spark to jump.
There is no way to test a plug with an OBDII reader.
Old Sep 5, 2018 | 06:38 PM
ronbros's Avatar
DITTO
Old Sep 5, 2018 | 06:54 PM
Matt300ZXT's Avatar
Most repair manuals have a page dedicated to multiple photos of spark plug conditions at the tip. They show normal conditions, too lean, too rich, etc. You can compare them that way. But from what I've seen in my past several days of research, if you already have them out, go ahead and gap check and replace...unless you have an inline 6 model, those look waaaaaaaay easier to replace lol
Old Sep 6, 2018 | 09:32 AM
leep123's Avatar
Hi OB,
I think to test them properly they have to be tested under compression. I think garages used to have machines for this but these days spark plugs are probably regarded as consumables and just replaced.
Good luck,
LeeP
Old Sep 6, 2018 | 09:50 AM
Matt300ZXT's Avatar
They probably came in useful for those old Oldsmobiles or Buicks, whichever ones that you had to essentially pull the engine to replace. I could see a tool like that coming in handy.
Old Sep 6, 2018 | 12:19 PM
Hi Matt
AJ16 is an Inline Six Engine
Old Sep 6, 2018 | 05:12 PM
Robman25's Avatar
I used to check my plugs with an ohm meter, if they showed considerable resistance I changed them. One of our club members has a couple of testing machines that can ramp up the spark rate so you can see the colour of the spark.
Old Sep 6, 2018 | 05:16 PM
Hi Robman
I did exactly the same and got a reading of Zero Ohms on all of the Six Plugs which was what I was after
arath25
Sep 1, 2014 07:23 AM
GvilleVDP
Jun 6, 2013 08:20 AM
dsetter
Jun 20, 2012 10:55 AM
SteveJacks
Dec 7, 2011 06:50 AM
urdrwho
Aug 9, 2011 12:36 PM
